Old 07-08-2005, 06:57 PM   #1 (permalink)
Default Key Wont Turn Over Sometimes?
Hey Guys,
do any of you have a problem where sometimes the key wont turn at all? as like its stuck or locked? its really annoying and sometimes can take up to 20 minutes of playing w/ it to finally get the key to turn and the car to start...anyway of fixin this?
1997 Disco SE -Forest Green
K&N Air Induction System
RoverTek Performance Computer
BORLA Exhaust System
OME H/D Shocks
31'' Good Year Wrangler MT Tires
RoverTym 2'' Lift Springs
Kenwood MP3 Player
Kenwood 800W Amp
2 10' JL AUDIO Sub's In Custom Box
In Car DVD System W/ 3 6.5'' Monitors
1990 Nissan Twin Turbo 300ZX 700HP
1992 Nissan Non Turbo 300ZX 300HP
Toddicus is offline   Reply With Quote
Old 07-08-2005, 08:46 PM   #2 (permalink)
4x4 Adventure Gear
John C's Avatar
I have that problem all the time. I've had new original keys cut and it doesn't help so I guess it's the tumbler (worn out).
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 07-08-2005, 09:35 PM   #3 (permalink)
ilovemydisco's Avatar
Sounds like your wheel is locked, which trips the locking mechanism in the ignition. One time that happened (it happens about once every few weeks but not like this) and I almost had to be towed because it took 2 hours to get it to work. If you notice that your steering wheel is locked, with the key in the ignition, pull hard on the wheel to one side, and it should unlock something and make the key turnable. I think this also might have something to do with the alarm going off, an immobilisation thing. Good luck.
~Erica~
ilovemydisco is offline   Reply With Quote
Old 07-08-2005, 10:03 PM   #4 (permalink)
Elephantitis penisitis
One or all or any combo of the following:
1 - tumbler going bad
2 - wheel locked too tight
3 - need lubricant in key hole
4 - alarm needs to be turned on then off to reset something or another
5 - your truck is of the female persuasion and you pissed it off so now that you put the key in her, she just won't turn on for you, no matter how much jigglin' you do, no matter how much you beg and plead...oops, my divorce is getting the best of me
Old 07-09-2005, 10:02 AM   #5 (permalink)
Just went through that problem with my Disco2. Not the steering wheel lock, not lubrication, not the key, not worn tumblers. It is an on/off problem with no in-between. I pulled it apart (had to cut slots in bolts to remove). There are electronics in there to keep the key from being removed while on. Possibly handles the buzzing when left key in as well.
I disconnected the wiring and have had no problems since. Don't know if that really was the cause, but it has worked fine since the disconnect. Security still works too. I also noted that the key needs to be pushed in to turn.
I keep the necessary screwdrivers and wrenches handy, just in case.
Note: dealer wants hundred$ for new lock. And the key will then be different from the doors.
Good luck.
Big Kat is offline   Reply With Quote
Old 07-12-2005, 09:15 AM   #6 (permalink)
texasrover's Avatar
I have the same problem at times. The only thing that works for me is pulling the key out and trying again and again then getting pissed off and forcefully yanking the steering wheel back and forth. Start over.... and repeat. Try to pull the steering wheel off... repeat. Bang on the steering wheel... then repeat.
Thus far this has worked ever time. Sometimes, it just take longer. LOL
Old 07-12-2005, 04:13 PM   #7 (permalink)
Just went through the same problem. Bent one key trying to get it to turn! Had to go back home and get spare key, also brought along a can of WD-40 to spray into ignition. Now works perfect! Try lubrication first before anything else, you might want to use graphite, WD-40 was all I had handy at the time!
Best of luck
bcball is offline   Reply With Quote
Old 07-12-2005, 07:11 PM   #8 (permalink)
TerryS's Avatar
Best of luck
Graphite is not a good idea in the ignition tumbler. It's very conductive and can short out the switch, which is a rotary wafer switch attached to the end of the tumbler.
Old 07-14-2005, 12:48 PM   #9 (permalink)
I have had the same problem in my series 1 Disco. I removed the lock assembly pulled the barrel out then gently filed the wafers back to flush, it is an easy job to do yourself or get a locksmith to do it.
aussie disco97 is offline   Reply With Quote
