Old 12-17-2005, 01:42 PM   #1 (permalink)
Herbie85's Avatar
Default Keyless Entry on a 95?
Do 1995 Disco I's come with keyless entry capability? If so how does one program the keyless remote?
Herbie85 is offline   Reply With Quote
Old 12-18-2005, 04:45 AM   #2 (permalink)
No relation to Felix The Cat
FelixLockhart's Avatar
Yes, they came factory with keyless entry/alarm. As for programming it, there's a lengthy procedure requiring two or more people that you can try, but I recommend just taking it to the dealer, they should only charge an hour labour for it. I spent an entire afternoon with two friends trying to program the thing, and finally gave up. It was worth $75 not to have to screw with it anymore :-P
Felix J. Lockhart
1995 Land Rover Discovery (Series 1)
FelixLockhart is offline   Reply With Quote
Old 12-18-2005, 11:23 AM   #3 (permalink)
I have a keyless on my discovery, the keyless part works, just not the alarm haha.
-Militant Grunt
Militant-Grunt is offline   Reply With Quote
Old 12-18-2005, 04:19 PM   #4 (permalink)
Super Moderator
Disco's Avatar
Default How to program a 'single button' remote.
Here's how you program your remote, if your key remote has the single button. If you have the two button handset, you can only get it programmed at the dealers.
If the handset button is pressed more than 4 times out of range, or the power interrupted by changing batteries, press the button 3 times within 5 seconds to re-sequence the handset with the vehicle's alarm system. If this does not work carry out the following instructions.
You will find this very difficult on your own so get someone to help.
1. Open the hood. Ignition off, doors unlocked, hood alarm switch depressed
with your finger.
2. Have a buddy sit behind the wheel and carry out instructions 3-9 within 8
seconds.
3. Switch ignition on.
4. Switch ignition off.
5. Lock doors (manually) by depressing door lock.
6. Unlock door manually.
7. Release hood switch.
8. Switch ignition on.
9. Switch ignition off.
If the alarm has been correctly accessed, the horn will sound and the LED alarm light at the console will light.
It is now possible to program two extra handsets of correct frequency to the vehicle's alarm ECU. This must be carried out within two minutes.
1. Press and hold down the button on the 1st handset until the dash
LED 'flashes'.
2. Press and hold down the button on the 2nd handset until the dash
LED 'flashes'.
The LED will extinguish if both handsets have been programmed correctly.
Good Luck!
Old 12-18-2005, 06:52 PM   #5 (permalink)
Otherwise known as STEVE
If your DI is like mine and you only have one working remote, you can program the same remote twice! I didn't know that until I tried it and now have working remote after years of not having a remote at all.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 12-18-2005, 11:42 PM   #6 (permalink)
Herbie85's Avatar
thanks alot everyone
