Old 06-21-2006, 08:41 PM   #1 (permalink)
Jarek M's Avatar
Gallery: 3
Default Knock, knock...
A knocking noise that started out 3 days ago getting progressively louder. The best I can tell it's coming from the inside of the oil pan. I already check for the loose converter, and the starter not retracting or any external loose components, nether one is the case.
The link is the video I took today of the underneath where the noise is coming from, you guys can actually hear the knock, knock
http://s32.photobucket.com/albums/d4...VI_0299AVI.flv
Jarek M is offline   Reply With Quote
Old 06-22-2006, 05:51 AM   #2 (permalink)
Have you checked your cats, sounds like one went thru a melt down? Get under your truck and hit both cats, see if one is ratteling, if it is, you first need to figure out why it happened and then replace one or both of the cats or the Y pipe.
