Old 07-14-2005, 06:47 AM   #1 (permalink)
texasrover's Avatar
Default Lifting, How high?
I am just curious. I have a 2" lift.
How high can you go before modification need to be made? I was told anything past three inches you would have to start making mods.
I used spacers, to lift the coils. Now, it is time to renew those springs. I would like to replace them with firmer, and taller springs (such as OME). just worried about passing that three inch mark.
Thanks in advance for any feed back.
Old 07-14-2005, 06:50 AM   #2 (permalink)
rmuller's Avatar
You were told right.. from 3" up you'll start running into problems which you'll have to address, anything from driveshafts to extending brakelines, to rearlinks, to radius arm, etc.. Check out 4x4ag.com or RoverTym, they can put together a package for you.
Old 07-14-2005, 09:38 AM   #3 (permalink)
Elephantitis penisitis
Every rover is different. Some can go to 3" or higher and have no issues. Be carefull replacing the radius arms and other parts with aftermarket fabricated ones. Rover uses solid formed pieces whereas the aftermarket part a cut and welded, therefore, weaker. To correct the steering wandering issues associated with a lift, make sure you change your steering damper and add a trutrac front locker to make it drive straight. Definitely will need extended brake lines. The general train of thought is this...decide what size tires you want to run and why, plus what tye of terrain you want to tackle, then lift accordingly. Don't go higher than necessary b/c you will then be too top heavy.
One idea is to do this...go with a 3" suspension lift, then add a 2" body lift - you will have 5" total but keep your center of gravity the same as a 3" lift, sans any roof rack weight and so forth.
As far as suspension lifts go..EE, rovertym, $afarigard, they all make good lifts that you can istall yourself even if you are minimally mechanically inclined.
As far as body lifts go, I have heard the best about rovertym. But then, I am sure there are other good ones out there.
My two cents/sense. I would like to hear from others on these issues as I am always willing to learn and expand my knowledge base.
Whatever you do, you have to take pics...unspoken rule here..
Old 07-14-2005, 10:12 AM   #4 (permalink)
4x4 Adventure Gear
John C's Avatar
Not all aftermarket manufactures cut and weld, some of them use solid formed pieces.
No need to add a Tru trac, you can get castor corrected radius arms or have the swivels drilled by RTE.
Correct.
EE sells (not makes) OME and RTE makes their own springs (has someone manufacture them).
I don't think anyone else in the US makes a body lift for Rovers, and yes they are well made and easy to install. It just requires some welding to extend the steering shaft.
I agree with you, just wanted to clarify a few things...
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 07-14-2005, 10:23 AM   #5 (permalink)
Wheeler
SCSL's Avatar
John, I think RTE makes body lift spacers for Rovers
(Although I personally would not install a body lift on a Rover. If you are looking to build-up, just cut. Why raise the center of gravity when your suspension will already be giving you 3"+ on a major build-up? The name of the game is always maximum clearance & suspension travel w/ lowest possible center of gravity.)
Old 07-14-2005, 10:26 AM   #6 (permalink)
4x4 Adventure Gear
John C's Avatar
That's what I meant, I don't think anyone ELSE makes them other than RTE. And they are well made and easy to install (I've done a few installs).
Yeah, I'm not a fan of body lifts either.
John C
Old 07-14-2005, 10:33 AM   #7 (permalink)
JesusIsLord
9dawgs's Avatar
Gallery: 2
What about the 2" TODDCO spring spacers? No mods needs to the drive shafts or brake lines for these right?
9dawgs
'99 Discovery I
'99 Chevy Astro 4X2 w/4" Lift (family truckster)
17' Basstracker w/40HP Mercury
11' Jon Boat w/numerous antique outboards
9dawgs is offline   Reply With Quote
Old 07-14-2005, 10:51 AM   #8 (permalink)
4x4 Adventure Gear
John C's Avatar
Like RoverX mentioned, each vehicle is different. I don't think you need to modify the DS or brakelines for a 2" lift.
Do you have the rotoflex in the rear driveshaft or u-joints? If you have the Roto you might want to consider replacing it with a u-joint DS.
John C
Old 07-14-2005, 11:14 AM   #9 (permalink)
JesusIsLord
9dawgs's Avatar
Gallery: 2
Probably, it's completely stock. If that's what it came with then they are there. I haven't crawled under yet to see though. I believe it was a grocery getter in another life...
Is the u-joint replacement just an exchange or will I need to take the drive shaft to a machine shop to weld the correct couplings on?
9dawgs
'99 Discovery I
Old 07-14-2005, 11:31 AM   #10 (permalink)
4x4 Adventure Gear
John C's Avatar
No, it's a piece of cake to do.
All you need is a driveshaft from an older Range Rover (87-93), the flange from the same RR and the spacer. Or you can purchase the flange kit from Atlantic British or your favorite parts supplier.
You can install new joints on the RR driveshaft yourself. You might want to replace the nuts on the driveshaft (transfer case side) while you're at it. It's easier to do the install using a propshaft tool (which is basically a thin wall socket).
The biggest problem is removing the peg from the old flange. I used a special tool called a Pully Puller Tool.
I'll put together some instructions on how to swap the Rotoflex for the u-joint style driveshaft this weekend.
John C
Old 07-14-2005, 11:45 AM   #11 (permalink)
John - thanks for the input. I, too, am interested in the swap out from the rotoflex. Please post the 411 when you have it put together. Is that your complany that is one of the sponsors of this forum? I am a firm believer in keeping things in-house if at all possible - keep it in the family.
Oh yeah...which aftermarket company doesn't cut and weld? That is some good 411 to have.
Old 07-14-2005, 12:40 PM   #12 (permalink)
4x4 Adventure Gear
John C's Avatar
Yep, we're the exclusive importer for Scorpion Racing products in the US.
Scorpion Racing makes a solid radius arm.
John C
Old 07-14-2005, 01:47 PM   #13 (permalink)
Wheeler
SCSL's Avatar
Scorpion working on anything for the DII watts links ?
Old 07-14-2005, 01:59 PM   #14 (permalink)
AdrianS's Avatar
SCSL
Scorpion has stuff on the "Drawing Board" but no eta. Tomcat is also working on it because they have started to use the DII axles on their race vehicles.
Adrian Strata
www.4x4ag.com
98 DI
34x10.50 Simex JT
2.5" SR lift
Evo Kit
91 RRC parting out
AdrianS is offline   Reply With Quote
Old 07-14-2005, 03:13 PM   #15 (permalink)
Too much money,not enough sense
Default QT engineering also make solid radius and trailing arms...
But trust me...RTE's cut and reworked arms are IMO far stronger than any punishment that could be inflicted on em...
Heres a rear arm on my rig...
And heres a Radius arm
As for installing a tru trac to make the truck ride straight...to me thats a cop out...the issue lies in the suspension...not the driveline...Get corrected arms or drilled swivels if you wanna do it right and eliminate undue wear on your tires...
My Tuppence
M,
Quicksilva is offline   Reply With Quote
