Old 01-18-2006, 06:17 AM   #1 (permalink)
Unhappy Light Problem
After I turned my headlights I noticed that my dash lights are not working. Upon further inspection my tail lights are not on while my headlights are turned as well. My brake lights do work however. I checked the under hood fuse box and fuses seemed fine. I do not have my Haines Manual handy. Any suggestions?
jdool76 is offline   Reply With Quote
Old 01-18-2006, 06:40 AM   #2 (permalink)
Banned
There are 4 fuses to the running lights...did you check them all?
Hank is offline   Reply With Quote
Old 01-18-2006, 07:38 AM   #3 (permalink)
If your fuses are OK, you should look at a failing head light switch.
Mike J.
Old 01-18-2006, 08:21 AM   #4 (permalink)
texasrover's Avatar
If you have rear fogs... I suggest you turn those on if you drive at night. No point getting a ticket for the lack of tail lights.
Check fuses. Then check them again. If you can find yourself a diagram... I would look over a few common ground points.
That is not a leak! That is undercarriage rust inhibitor.
98 Discovery
Old 01-18-2006, 11:25 AM   #5 (permalink)
JamesVee's Avatar
It is most definitely a fuse. Just brought in my 99 DII for the same thing. Yu have to look close. From what I remember, it is a fuse in the regular fuse panel. 10 amp. Cant' remember exactly what number though. Not 27, I do remember that much.
Check out my websites: Family Trophies and Africa Pictures
JamesVee is offline   Reply With Quote
Old 01-18-2006, 07:41 PM   #6 (permalink)
I will use all you suggestions. Duh!! Rear fog lights do have those never thought about running those. Where and how do I replace the head light switch?
Old 01-18-2006, 08:42 PM   #7 (permalink)
Otherwise known as STEVE
You said you checked the fuses under the hood- the fuse that you probably need to replace is in the INTERIOR fuse box, under the steering column.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 01-19-2006, 07:03 AM   #8 (permalink)
I will give the interior fuse box a look. I have heard that the head light switch will only take about twenty min to fix. Can you shed any light on this subject
Old 01-19-2006, 05:28 PM   #9 (permalink)
The fuse for the lights is in the pannel under the dash, driver's side. I think it's identified in the owners manual if I remember correctly. Change it out and if it fails again you'll need to look for a ground. I had this problem and it turned out to be a chaffed wire to the passenger tail lamp in the bumper. The wire chaffed on the frame enough to go thru the shield and would blow the fuse when it contacted the frame. Some electrical tape and additional chaff protection resolved it.
kferg is offline   Reply With Quote
Old 01-19-2006, 05:56 PM   #10 (permalink)
the switch is easy to replace but expensive. usually the fuse is the problem.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 G4 Disco
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1973 SIII 88
Old 01-20-2006, 09:09 AM   #11 (permalink)
KFERG, I will take a look for the fuse and get back with you. It is tough for me to find time; work, school, girlfriend, and the kids keep me pretty busy. Is it a long process to find that fuse? I have a 95 disco. Is there a way to meter the wires so I can elimanate where it is and is not?
Old 01-20-2006, 09:11 AM   #12 (permalink)
Muddy, I looked for such a fuse box (interior) but I was unable to locate it. I have a 95 Disco. I am hoping that it is a fuse problem cheaper route. Can you shed some more light for me on this?
Old 01-20-2006, 02:41 PM   #13 (permalink)
No relation to Felix The Cat
FelixLockhart's Avatar
Ok, on the driver's side, under the steering wheel, there's a large panel that should be the same colour as the dash. The whole panel opens. There should be two round plastic locks that can be turned with a quarter (or just your fingers, depending on how many times it's been opened in the past). Once the panel is open, the fusebox should be pretty obvious.
Felix J. Lockhart
1995 Land Rover Discovery (Series 1)
FelixLockhart is offline   Reply With Quote
