Old 11-30-2007, 01:26 PM   #1 (permalink)
Default Live data on my o2 sensors Help!
I am getting like 9 mpg and i need to fix this crap.
This data was taken at idle.
Bank 1 Sensor 1 = 1.02V %.0.8 to %3.1 Lean
Bank 1 Sensor 2 = 0.000 to 0.005
Bank 2 Sensor 1 = 0.025V %24.2 Very Rich, probably maxed out.
Bank 2 Sensor 2 = 0.000 to 0.005
Should I switch the front sensors and regroup?
Fuel pressure stays up after shutoff around 30PSI, I replaced fuel filter along with champion plugs about a month ago. I can't afford to drive this thing at this pace. Any suggestions?
bt93 is offline   Reply With Quote
Old 12-11-2007, 11:23 PM   #2 (permalink)
The Urban Motorist
Adam in NYC USA's Avatar
Arrow
It helps to know how much mileage you have , what kind of motor oil you have, have you performed a fuel system cleaning, even what pressure in your tyres.
Change your oxygen sensors after extensive mileage. Clean the MAF sensor and rinse out the intake ducting. Replace your airfilters and your fuel line filter. Drop in some Techron Seafoam or B&K.
inert facts.
96 Disco-VSS and the wheel speed sensors Len Discovery Series I 0 08-29-2007 06:22 PM
Misfire codes after replacing O2 sensors??? Len Discovery Series I 13 08-22-2007 02:35 AM
Motion / pressure sensors wimp Discovery Series II 8 03-16-2007 11:20 PM
O2 sensors? Help! me.guevara Discovery Series I 21 03-17-2006 03:36 AM
Oxygen sensors pavel Discovery Series I 7 12-06-2005 05:48 PM
