Old 02-07-2008, 12:39 PM   #1 (permalink)
jed
jed's Avatar
Default Lock, Alarm problem
My power locks are malfunctioning well sort of I think my neighborer's key fob
is locking my disco my fob hasn't worked since I got the truck, I live in the country and have dogs so some getting in it hasn't been a issue.
I would like to disable the power locks and alarm e.g. pull the fuse I don't think
it will be quite that easy but here's to luck.
thanks jed
96 disco I SE auto if that makes any difference.
96 Discovery SE
72 M35A2
I'd rather push my landy then drive a cruiser!
jed is offline   Reply With Quote
Old 02-10-2008, 01:37 PM   #2 (permalink)
Oil Field Trash
ensignderrickman's Avatar
Gallery: 4
The left fuse of the top satalite in your fuse box section will disable the alarm/ at least it does on my 95, however it than won't start. Good for parking long term deep in the hood, but not very user friendly on a regular basis. If you want to do without the power locks you probably could pull the central lock fuse and not have the locks work without any other side effects
95 Disco (flipper) Roof rack w/ twin jerry can holders-Deer Killer-Infinity audio system w/sub Already rolled it onto it's side Currently waiting on back ordered RTE parts for a 3 inch lift, 2 inch body lift.
ensignderrickman is offline   Reply With Quote
Door Lock Problem RoverFan26 Discovery Series I 1 08-11-2007 04:08 PM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 03:50 AM
Alarm problem again in 95 Rangie gr8rangie Range Rover P38, Mk III and Range Rover Sport 0 03-09-2006 06:19 PM
99 4.6 is superlocked and won't reset Spring Range Rover P38, Mk III and Range Rover Sport 9 12-05-2005 04:46 PM
Intermittent Driveline Vibration at 60MPH AdrianL Range Rover Classic 10 06-24-2005 07:52 AM
