loose steering at the steering box 98 disco - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 5 (permalink) Old 02-03-2011, 04:27 PM Thread Starter
Quoted: 0 Post(s)
i got tons of slack in my steering box at the end of the steering column. i have 11 o'clock to 1oclock play at the box with no response on the arm. i read somewhere that you were able to adjust the steering box somehow, also able to disasemble them to check for internal wear. just wonderng if somebody could give me a rundown of how to adjust the box or if its even possible before i go ripping it apart. any other thoughts on the matter would also be apreciated.
98 discovery, flanged liner 4.6, 2" terrafirma medium duty lift, flexi flares, qt services diff skids,tactical rovers front bumper, terrafirma steel steering skid 285/75/16(33" x 11.50").
Future plans: finish rock sliders, wear out my new tires then go bigger
P.S.if i only knew 4 years ago to stop all the leaks and problems all you have to do is replace EVERYTHING. this would have been a much simpler process.
DiscoPA is offline
post #2 of 5 (permalink) Old 02-03-2011, 06:01 PM
Master Land Rover Tech
aachour83's Avatar
Quoted: 0 Post(s)
Yes they are adjustable. I have done one before but it was a brand new vehicle. Does your steering have slack only when the wheels are straight or does it also have slack after you turn the wheels all the way right and left. If the box is out of adjustment it will be loose at all steering positions. If the box gets looser and tighter than you will have a very worn steering box and would be easier just to replace it with a reman unit.
aachour83 is offline
post #3 of 5 (permalink) Old 02-03-2011, 08:26 PM Thread Starter
Quoted: 0 Post(s)
ya it has slack at all times, seems to have just started in last few months its a 2 hour turn of the wheel to get it to go any direction whether strait or or when counter turning. also seems to have developed a sort of loud humming noise when the engine revs gonna look into this weekend also.
DiscoPA is offline
post #4 of 5 (permalink) Old 02-05-2011, 10:33 AM Thread Starter
Quoted: 0 Post(s)
rave manual show the adjustment off the box for steering backlash, thats exact opposite of my problem i think. it says tighten bolt down to remove backlash, so do i need to loose it to add backlash?
DiscoPA is offline
post #5 of 5 (permalink) Old 03-01-2011, 09:45 AM
Quoted: 0 Post(s)
Hard time steering straight
Hi my name is Moses and I was in need of a car and someone showed up with a 97 Discovery and I’m have a hard time keeping it straight. It has new tires, so the tire pressure is good. I still haven’t looked at the tie rods and I’m guessing it’s going to be the steering gear box. Is there a repair kit for steering gear boxes, or is that something I can adjust. I’m a fan of Land Rovers and now I got one and looking what direction to go.
moeana714 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
1999 disco 2 89,000 slightly over heating, 3 amigos and loose steering disco2mjp Discovery Series II 4 05-08-2010 09:21 PM
95 Disco, Q's about steering box.... 2000-Disco Discovery Series I 3 11-16-2008 12:21 PM
Steering Box Leak 95 Disco 1 Chapnick Discovery Series I 3 07-01-2008 04:25 AM
power steering flush and steering box new rover girl Discovery Series II 1 10-01-2005 06:23 PM
Disco 1 Steering Box Leak taylorbob1 Discovery Series I 4 04-06-2005 08:13 AM
You may post new threads
You may post replies
