Old 04-27-2008, 08:15 AM   #1 (permalink)
discowilson's Avatar
Default lugs
anyone know what size socket i could use to take my lugs off, so i can fix my brakes, i do not have a jack or a lug wrench
1996 D1 SE7
discowilson is offline   Reply With Quote
Old 04-27-2008, 08:43 AM   #2 (permalink)
A 1-1/16" socket will do it. If you have the caps over the lugs and they've expanded and cracked because of winter get yourself a 1-1/8" socket too, you'll be glad you did
Ben Rover is offline   Reply With Quote
Old 04-27-2008, 09:44 AM   #3 (permalink)
thanks!
1996 D1 SE7
Old 05-26-2008, 06:55 PM   #4 (permalink)
I found this post useful.
So I took my 99DII to get the tires balanced and rotated and found that I had one lug completely rounded off. They basically said they couldn't do anything for me and refunded my money.
It actually wasn't that bad of a fix. I just took a pair of vice grips and locked on the lug, then hit the end of the wrench with a hammer. It took 3-4 tries but the cap eventually came off.
Hopefully this helps someone.
mprocopi is offline   Reply With Quote
Old 05-28-2008, 10:14 AM   #5 (permalink)
mick968's Avatar
Whats up with the caps?They suck.I have a big metric 4 way and it got stuck on them and I had to chizel it off.The OEM lug wrench won't begin to fit on them now.Can you take the caps off?
mick968 is offline   Reply With Quote
Old 05-28-2008, 03:20 PM   #6 (permalink)
You're better off getting a 1-1/8" socket. If you remove the caps you'll end up with mangled lug nuts all rusted up underneath.
Old 05-31-2008, 10:03 AM   #7 (permalink)
antichrist's Avatar
Just to be clear, this is only if the chrome caps are distorted. If the caps are in good shape, 27mm or 1 1/16"
If I'm at a tire shop, I have them use my socket.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1
95 D90
Old 06-02-2008, 03:55 PM   #8 (permalink)
yeah i went and bought a 1 1/16 socket the shit set me 8 fucking dollars.
1996 D1 SE7
Old 06-11-2008, 10:23 AM   #9 (permalink)
"You're better off getting a 1-1/8" socket. If you remove the caps you'll end up with mangled lug nuts all rusted up underneath."
Commenting on the above, I have a '97 Disco. I could hardly get my socket on the lugs and then couldn't get it off again. The stainless covers were so distorted from tire store abuse. I grabbed my lug with a pair of vise grips and slid a bolt through the hole in the lug. A couple of good wacks with a hammer sent the cover flying. All of the lugs were in great shape underneath as they are cadmium plated. They have a very distintive look now that sets my otherwise common alloys apart. Other guys have asked me where I found the custom lugs. Would do it again in a heart-beat.
MH
Empty Pockets is offline   Reply With Quote
Old 06-11-2008, 01:25 PM   #10 (permalink)
Elemental's Avatar
How much do you think it should have been?
DII OEM Steel wheel kit- 5 wheels, lugs etc Muddy Oval Land Rover Parts and Accessories 0 03-07-2007 11:25 AM
Steel wheel lugs on alloys? Sam C. Wheels and Tires 6 02-02-2007 07:23 AM
Noise... lugs. texasrover Wheels and Tires 1 10-13-2006 06:05 PM
Parting 94-04 Discoverys and 87-95 Classics willtillery Land Rover Parts and Accessories 37 05-13-2006 08:31 AM
20 P38/DII Lugs = $400.00!!!? keptin Wheels and Tires 6 12-29-2005 02:19 PM
