Old 04-15-2007, 03:10 PM   #1 (permalink)
Home of "rover" the '96 Disco 1
roverpwr's Avatar
Default Manifold to down pipe still ticking
I got all three studs replaced and a brand new gasget from AB installed, still ticking from that connection, passenger side doesnt do this. Its not the cat, its brand new. I am wondering about putting a second gasget in there to see if that seals it up. Not much to AB's gasgets, espicaly if the mating surfaces are not perfectly smooth, I dont see how they can seal up. Its basicly a thin piece of metal. Is there something better, the ticking really detracts from the nice V8 rumble. Replaceing the manifold or Y pipe isnt in the budget as who says another used manifold wont do the same thing. There are no cracks anywhere either, myself and the exhaust mechanic both looked it over closely. Any suggestions for a better gasget between the manifold and down pipe???? Thanks Mike and Michele T
1996 Discovery 1 SE7
White with tan leather
Tinted windows
Brush guards
factory fog lights
roverpwr is offline   Reply With Quote
Old 04-16-2007, 02:43 AM   #2 (permalink)
Series Moderator
onslow's Avatar
generally I use a small amount of exhaust assembly paste on the mateing surfaces this will cure your problem
Current fleet
86 90 V8 in bits
86 RR classic Under repair
94 Disco TDI 3dr ex-police 256k and still going
80" coil sprung V8 auto Trialer in progress
71 2a Trialer V8 auto,parabolics,6" shackles,power steering awesome machine
Stuff I have had at one time or another
76 S3 LWB
65 2a ex mil swb
71 2a swb safari
67 2a 1 tonne TACR
57 S1 V8 SWB
81 S3 SWB diesel
82 s3 SWB diesel
82 RR 2 dr perkins diesel
83 RR 4dr V8
84 RR 4dr V8 LPG
83 RR 4dr V8 LPG "in vogue"
88 RR gm 6.2 V8 Diesel
89 RR 3.5 mazda TDi
75 S3 LWB stationwagon
75 S3 2.6 LWB
86 110 2.5D
91 disco V8
91 disco TDi
89 disco V8
81 RR isuzu 2.8 TD
Old 04-16-2007, 03:49 AM   #3 (permalink)
Ian Matthews
p76rangie's Avatar
Heat proof sylicon will generally fix it.
Old 04-16-2007, 04:32 AM   #4 (permalink)
roverpwr's Avatar
I plan to look at it more tuesday after work, she is down right now with a bad water pump bearing, been hearing a bad bearing noise, was looking for the the leak and watch the water pump pully kind of wallowing around, so I shut it down and there it will sit till the pump gets here, Got one from BP via UPS Red so it will be here tuesday morn. We have a trip to take on Thursday and I need the Disco for the trip. Guess I am driving the Jeep the next two days. YUCK! Thanks Mike
Tinted windows
Brush guards
factory fog lights
Old 04-16-2007, 08:01 AM   #5 (permalink)
Mostly Harmless
kellijo's Avatar
I've had the exact same issue... I recently had exhaust manifold and all new head gaskets, etc....changed, but still the tick, but lower sound w/acceleration....
Anyway, here's a good link to possible problem that may save you some time. Take note to HANK's post about the rocker arms....
'95 engine ticking - any suggestions?
I'm sure someone will chime in if I'm way off base here. Good luck!
*Kellijo*
98 D1
'If we worry too much about ourselves, we won't have time for others.'
kellijo is offline   Reply With Quote
Old 04-16-2007, 02:33 PM   #6 (permalink)
roverpwr's Avatar
This isnt up in the engine bay, infact you cannot hear it from the top side with your head under the hood. I can see a soot trail on top of the down pipe from a weld near the elbow and goes back towards the cat. I am thinking they didnt get the weld completely sealed up when they replaced the cats, the previous owner didnt replace the whole Y pipe, but had replacement cats welded in. The did a good job from what I can see. If its leaking from a joint, a little JB weld will solve that. To rainy right now, and its down waiting on a water pump, I dont plan to start it again till its replaced. Thanks Mike
Tinted windows
Brush guards
factory fog lights
Old 04-16-2007, 06:07 PM   #7 (permalink)
smoke it with nitrogen.
