2 questions:
my 97 disco won't start....i thought it was the cylinoide on the starter...but thats not it...put a new starter in...checked all the wiring...still won't work....i mean it will start but it takes about half an hour of just turning the key....anybody have any idea whats goin on? also...where is teh fuse for the air conditioning or fan...cause while i was messing with the wires i blew something cause my fan won't work ![]() |
Location: currently living in kuwait....but watch this space!
let me see if ive got this one right....the engine turns over...and fires eventually and you thought the solenoid was faulty and replaced the starter motor because??????maybe a fuel pressure problem at a guess....
Elephantitis penisitis
Is the ECU damp?
#4 (permalink) | |
So about this SOLENOID, which is attached to the side of your starter, and does two things: engages the bendix, and activated the motor. Is the starter working but the engine does not start, or, does the starter not spin? In other words, is the engine cranking but not firing, or is it not even cranking? |
Super Moderator
Assuming that your engine is turning over but not starting, you need to go back to when it was starting, and what you did. Have you played around with the spark plug or coil leads?
When you turn over your engine do you have a spark at the plugs? If you have a spark, then you need to check that your fuel pump is working. If you don't have a spark, get back to us for further instructions.
i replaced the whole starter beacuse the solenoid (thanks) is attached to the starter and i called just about every place in the world and they don't come separatly. The starter spins, but not enough, it stops before the engine can turn all the way on. That's why i thought it was the solenoid
4x4 Adventure Gear
Sounds like a timing issue to me..
John C 1996 DI - 3" AG lift 1995 DI - Scorpion Racing Extreme Kit 1991 RR - parting out (few parts left) 1990 Kawasaki KL650B Tengai 1989 Kawasaki KLR650 |
i took it to the shop and it turns out that something with my alarm system went wrong, so it was triggering the fuel pump shut off. Thats why it wasn't starting all the way, and we burned up my starter in the process....since we kept trying it. It did start eventually, but that's because enough fuel finally got into the engine...I never woulda figured that out...alarm system and a blown starter...man i love my land rover
