Old 12-17-2004, 05:21 PM   #1 (permalink)
Unhappy Mechanic's Help Please
I could use a little info as my manual is still in route from the UK.
I get error code 14 on the error code box under the seat so I bought a water temp sensor to replace the old one but before I do I'd like to know how to reset the codes so I can duplicate the error one more time before I start taking things apart. (which is the "serial cable" I'm supposed to disconect to reset the box etc.)
Also how do I test the old sensor's continuity to check and make sure it's really gone south before I remove it.
For a little back background here we go: The Disco starts reluctantly when hot. Sometimes not at all. And when it does it runs rough until underway. I don' think it's the fuel pump as it happens only when hot and it's worse the hotter it gets.
Any info is greatly appreciated.
thanks
Eric
62sunbeam is offline   Reply With Quote
