Well guys...if you havent done so already, i think its time you did!...switch to a K&N FIlter that is!!!!....wow...you can really notice the increase in the fuel-mileage numbers. Also using that new (new to me atleast) SAE 10-40 4x4 Oil from Quakerstate and man...you can barely feel the engine!...when im at intersections i have to turn the radio down and put the window down a bit to make sure the engine is on!!..NO LIE!!...Next on the to-do list, Ignition: 7mm Wires, Rotor and Cap, Bosch Platinum Plugs, Bosh Coil, and Optima Battery (btw, can anyone tell me if it would be ok to use the Yellow Top as the main bat or not?)
JC... 1996 Discovery SE - The Blue Marlin - gone =( 1965 Series IIa 109 RHD Dsl - Wilks www.TerraTrekker.com
rovering??
almost ditto
i switched from 20w50 to 10w40 and trust me the engine responds much better,runs quieter and i love it. the previous owner had already upgraded to fatter wires, now i need a k&n which ill be putting in soon . |
Super Moderator
Congrats!!! What kind of MPG increase did you get?
Land Rover-less. -------------------------------- 2006 Infiniti QX56 - Loaded 2002 Discovery II SE - SOLD! 1999 Audi A6 Avant Quattro Tiptronic - Slammed on RS4 18's 1996 Mariah Talari w/350 Mercruiser and Ron Hill Marine Go-fast parts.(Presently in Dry Storage) |
I havent done the math yet but im going to do it a little later when i go to work so ill post up there...BUT the needle moves A LOTTT slower now!
#6 (permalink) | |
Though not often listed, the Blue Top is still available and is a good choice for both applications when only one battery is fitted. |
GEEZEE..THANK YOUU!!!..HAHA...DAAAANG...that question has been pending for like 2 weeks now....thanks for clearin that up for me Terry...u da mannn!
#8 (permalink) | |
#9 (permalink) |
Super Moderator
Terry,
Are you 100% sure about the Yellow Top Optima? I have used the Yellow tops on all of my vehicles for years, without a hitch. I use the Blue's for my boat. Ryan
#10 (permalink) | |
Winching is where alot of people differ as to Red or Yellow. My thinking is that the Yellow will handle this sustained drain of the high wattage (Amp x volts) winch motor, better than the red top, but since most people don't have to run out 130 of cable and pull full load the whole amount, the red top appears to work fine here, though I doubt it could hold up to the yellow for a long load. Just curious, do you keep your Disco in a garage on those cold MN nights? I don't think you would feel the same about a Yellow top as a starting battery in Greenville Maine winters where the temps are in the neighborhood of -20 F in the mornings |
#11 (permalink) |
well it certainly does sound like it did make you an expert..haha...good one about the inlaw!...well...i dont winch (even tho i should, been stuck in deep mud twice already)...so i guess i'll go for the Red Top
#12 (permalink) |
oh man, that sounded like a bit of sarcasm, i was being serious tho...thats some useful info you learned there.
#13 (permalink) |
If you elect to add a second battery, I really don't like these battery isolaters out there. I personally prefer a plain old marine battery switch (1,2,BOTH, OFF)
#14 (permalink) |
Super Moderator
I see your point, and understand the theory. My vehicles mainly stay inside the garage at night. Over the past three years, and most specifically with my Audi's, I ran yellow tops in those and I travel quite extensively up to Fargo North Dakota every other week for 3-4 nights. Boy, it does get cold up there! I only had one issue with it not starting after it sat in the Ramada parking lot for 3 days when it was -30F and I had left the friggen radar detector plugged in. A quick jump and I never had an issue again. I did run a lot of stereo gear in those vehicles so that was the intial reason chose the yellow's. You learn something new here every day!! Thanks Terry!
#15 (permalink) | |
rovering??
and guess what? it sure put A BIG FREKIN GRIN ON MY FACE. how does 20 sound? thats rite u read it right 20 miles/gallon on my 93 rr lwb. it sure surprised me.and all this just after switching to a lighter oil.Now gonna be going to get my green rangie a k&n. and she'll be greener, i hope. and if that works fine she's gonna get a snorkel. <thanks bout all the info about the battery's.> ![]() |
