Old 08-23-2005, 10:09 AM   #1 (permalink)
Fridge Largemeat
Badger's Avatar
Exclamation More Electrical Problems!! HELP!
My back windows refuse to roll up. I have replaced the fuses tested the wiring. I have done almost everthing I can think of except take apart the door. The wet and cold is coming, I need those windows up!! Any suggestions?
97 Disco SD
The trail is the thing, not the end of the trail. Travel too fast and you miss all that you are traveling for.
Badger is offline   Reply With Quote
Old 08-23-2005, 10:14 AM   #2 (permalink)
Fridge Largemeat
Badger's Avatar
Where is the window lift ECU located?
Some of these questions may sound silly but I am used to working on VW.
97 Disco SD
Old 08-23-2005, 11:21 PM   #3 (permalink)
pavel's Avatar
The controller should be behind the glove box. Chances are there is a fault in the circuit board otherwise it is more likely one rear window would still work. For pictures and details on this repair try: www.discoweb.org/window/
Old 08-24-2005, 09:48 AM   #4 (permalink)
Fridge Largemeat
Badger's Avatar
Thankyou!!!!!!!! Your awesome!!
97 Disco SD
Old 08-24-2005, 08:37 PM   #5 (permalink)
Fridge Largemeat
Badger's Avatar
Well, it worked fine after I soldered it until I snaped the chip in half while trying to stick it back in the box.
Now my all my windows are stuck down. I just ordered a ECu off Tide Water's ebay store. Hope it comes soon.
97 Disco SD
Old 08-25-2005, 09:49 AM   #6 (permalink)
pavel's Avatar
bad luck Badger! Just keep reminding yourself of all the money you are saving over a dealer repair....
Old 08-25-2005, 10:15 AM   #7 (permalink)
Fridge Largemeat
Badger's Avatar
true, true.....
97 Disco SD
