Old 03-04-2007, 05:25 PM   #1 (permalink)
Mark Miller's Avatar
Default Is my exhaust manifold cracked? Pic Inside>>>
Just curious..
And if I drill it, can it keep it from getting bigger.
Mark Miller is offline   Reply With Quote
Old 03-04-2007, 05:55 PM   #2 (permalink)
96owner's Avatar
just jb weld it. it will hold. or theres aways some one parting out a disco
Delaware Mother******!
1996 Disco
Myspace
mods:
OME HD lift (thaks max)
zombie
96owner is offline   Reply With Quote
Old 03-04-2007, 06:59 PM   #3 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Check your local dealer....seriously! The Louisville dealer is selling them brand new for $80! RN and AB are around $200. The reason I was given for the price diff is this manifold from the dealer is a redisgned part by LR to address the cracking problems. I have yet to buy one, but will before this month is over. Brand new for the price of another used one from a salvage vehicle.........no need to think that one over.
1997 Disco 1
2000 Disco 2
1989 RR(gone but not forgotten )
Miami Valley Land Rover Society
www.mvlrs.com
ON WISCONSIN
Old 03-04-2007, 08:51 PM   #4 (permalink)
If you want to save a few bucks, I have manifolds for $35 plus shipping. You can contact me at paulgrant@mac.com if you're interested.
Thanks,
Paul
Old 03-05-2007, 11:26 AM   #5 (permalink)
I got the used exhaust manifold installed. (From Paul Grant, Thanks)
Was easier than I thought, all the bolts came out with little effort.
I did break one bolt on the old manifold.
Makes a big difference, I'll miss the co2 dizziness.
The lower gasket was already blown out.
Total cost with all new gaskets was $80.00 and took only one evening.
Old 03-05-2007, 01:59 PM   #6 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Glad it all went well for you, I am still fearing the worst(broken bolts) when I do this job. At least I am close enough to work that I can bike(or use my wifes D2 ), while I soak those bolts in vast amounts of PB!
1997 Disco 1
2000 Disco 2
www.mvlrs.com
ON WISCONSIN
Old 03-07-2007, 06:16 PM   #7 (permalink)
I know what you mean, I bought a brand new can of blaster.
I guess the bolts were easy due to the blown gaskets.
Old 03-07-2007, 06:44 PM   #8 (permalink)
Rocky Mountain High
Funrover's Avatar
Sweet..... Now you are set up for dual exhaust on that side...LOL
Old 03-08-2007, 12:48 AM   #9 (permalink)
I've always had good luck over the years with stainless steel bolts for holding the manifold against the head. Since we're no talking about a lot of torque and Rover makes those god awful lock washers, stainelsss steel is more than strong enough for the job. I've never had a problem with removing a stainless steel bolt in this application. So, next time you need to pull the manifold you might want to consider stainless steel bolts instead of plain steel.
As far as removing the nuts from the studs on the down pipes,a great way to avoid snapping the stud is to use an impact gun. When you use a conventional wrench or ratcheting wrench you are continually building up torque as you try to remove the nut. The likelihood of breaking the stud is far greater. When you use an impact gun, usually, the worst thing that happens is you remove not just the nut but the whole stud.
