Old 05-26-2008, 09:53 AM   #1 (permalink)
Default Need help diagnosing a problem
Hi all, I have a V8 Fxi done 120k miles, automatic. When last driving her she shook at around 50mph and lost power. Would not sit in gear waiting for traffic lights had to put her into neutral or stall.
Now runs for maybe 10 mins then stops. Will not restart. Wait a couple of hours and she will start again.
I am not sure whether this is an engine problem and it is seizing or something to do with mixture or engine control electronics.
Any help on further diagnosis would be appreciated.
Thanks,
Doug
douglas1720 is offline   Reply With Quote
Old 05-31-2008, 03:09 AM   #2 (permalink)
if no codes then start looking at sensors when it gets hot. Its possible when it warms up the resistance in a wire is changing causing the engine to shut down. heat it up and when it shuts down check the resistance and voltage drop across the cam and crankshaft sensor circuits.
Old 05-31-2008, 05:22 AM   #3 (permalink)
Thanks, I am away from home at the moment on business when I get back I will check this out. I will let you know in a couple of weeks. Thanks.
Wierd Range Rover Classic Problem NikeCheck246 Range Rover Classic 5 03-06-2008 10:56 AM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 03:50 AM
rr v8 4.4 nikasil problem???? please help. 2002hse General Land Rover Discussion 4 10-19-2005 01:00 PM
rr v8 4.4 nikasil problem???? please help. 2002hse Range Rover P38, Mk III and Range Rover Sport 2 10-12-2005 08:11 AM
Intermittent Driveline Vibration at 60MPH AdrianL Range Rover Classic 10 06-24-2005 07:52 AM
