Old 08-15-2005, 09:47 AM   #1 (permalink)
Post new guy needs help, idleing problems 1995 disco.
Hi all i am haveing no luck with getting my idle correct. I took it to the dealer to get it checked out and they have no idea why the stepper motor light is comeing on. I have changed all these parts and all are brand new oem. tps,new injectors,new fuel pressure regulator, new stepper motor, new distribtutor, wires,plugs, basicaly the whole top end was rebuilt new. new o2 sensors and so on. what the problem is when you put it in drive it goes in to stupid mode and wants to loose its idle and stall and the stpper motor light comes on but when you are driveing it,it is fine? any help on getting this fixed would be great. please email me if you have any ideas on how to fix this problem. thanks George
www.jimmy1hendrix@aol.com
krigtt198 is offline   Reply With Quote
Old 08-15-2005, 06:15 PM   #2 (permalink)
What is the stepper motor "light"? What rpm is your truck idling in neutral? What codes is she throwing?
1994 Discovery
vray is offline   Reply With Quote
Old 08-15-2005, 06:34 PM   #3 (permalink)
http://www.discoweb.org/faq/stepper.htm
When you get there you can do a search on this topic. Lots of info.
jhmover is offline   Reply With Quote
Old 08-15-2005, 08:02 PM   #4 (permalink)
Mod. --- I'm watching you
darkknight1999's Avatar
So your saying if you start the truck and put it in drive and just sit there it will stall but if you put it in drive and go its fine until you stop and then it stalls again??
-John
Some of my favorite quotes:
"what you do in life, echo's in eternity..."
"death smiles at us all... all a man can do is smile back..."
1999 Discovery II SE-7
darkknight1999 is offline   Reply With Quote
Old 08-17-2005, 04:34 PM   #5 (permalink)
Post re:new guy needs help, idleing problems 1995 disco.
the idle is at 650 to 700 in nuetrual, and the code that comes up is number 48. But after a little bit it goes to low cam idle and wants to stall. i wonder if i have the computer reset would it make a difference or is it my injectors causeing the problem, they are running at 22lb and that is what it calls for. or can it be timeing? my fuel pressure is good. and the o2 sensors are new and they are reading -10 and -11 and they should be at +1/-1. so what it is telling me that my fuel is running lean?. any help would be great. thanks agian
George
