Both of my rear brake lights (in body) are not working, only the center. I've had intermittent problems with them for a long time (have replaced bulbs etc, work temporarily, but then go out again. I need to have the whole light kit replaced. At the time I brought it in, one light was working so we were just discussing one light. Technician said just bring it in (he couldn't do it that day), it's easy to install and he could do it in 15 minutes at just the cost of the light.
Now the other brake light is out, and I called my service advisor at Landrover and he said it's going to take 1 1/2 hours to install both lights, and I know this guy is going to charge me for labor. Question: How long should it take to install two rear body light kits? I don't want to be taken. Next question, do you think I should have an independent Import Auto shop do it? Labor's cheaper. Thanks for any input!! Michele |
LRO Founder
You mean they are telling you to replace the WHOLE tail light assembly because the light's keep burning out??? I SERIOUSLY doubt that is your problem! I would not replace the tail lights, unless there was some obvious corrosion issues with them internaly.
Get it checked somewhere else.. And if you do need to replace the rear lights, it's a simple screwdriver job. You can do it yourself... it's not a big deal. Serg
Current Vehicles: 2003 BMW 540iT M Sport 2005 BMW R1200GS 2004 Element Skateboard (Indy trucks, Bones Swiss, etc...) Past LR's: 1995 Range Rover LWB Classic 1995 Range Rover LWB Classic 1997 Discovery XD 1995 Range Rover LWB Classic 1995 Range Rover LWB Classic 4.0 |
The Urban Motorist
![]() Join Date: Sep 2004
Hello from Adam in NYC
![]() Are the bulbs just off or they actually burnt out? I just ran down to Baltimore from NYC and back and found out my rear passenger brake light did not work. Went to my favorite work spot which has no audience, open the rear door and had to remove that jump seat (grrr. what a pain). The screws on the jump seat are the Torx type. Use a complete screwdriver set with all the necessary bits to save time. I then open those panels with a Philips (star) screwdriver. You will see the access panels for the rear lights in the rear corners. There are little buttons you have to flip over to get access to the fastener. In my 1996 D1, looking at the fixture for the lights,there are several knobs like those on a stove. Turn and the bulb comes out. I looked into the bulb and the filaments were whole. Took the bulb out of the holder and saw that the metal connection had corrosion on it. Cleaned it with a strong brush and put it back in. Light turned on. If you are doing it by yourself, use a heavy bag and lean in on the brake pedal. All the brake lights should then turn on. You can also use an anti-theft device in a pinch. Hope I was some help ![]() PS Just had to do the rear door too. Rain got in and had to do the WD40 trick. |
#4 (permalink) | |
4x4 Adventure Gear
It's typical of the Disco to have this problem because of the water leaking in behind the panels. Trust me, remove your rear carpet and I'll bet you the cargo floor is wet. Good luck.
John C 1996 DI - 3" AG lift 1995 DI - Scorpion Racing Extreme Kit 1991 RR - parting out (few parts left) 1990 Kawasaki KL650B Tengai 1989 Kawasaki KLR650 |
#5 (permalink) | |
The Urban Motorist
Thanks for all your input everyone. It's a 97 Discovery. I just went out and tweeked the prongs on the bulb holder, and the brake light went on. I have done this before, and I think what the problem is is that the lamp gets jostled loose when I go over bumps in the road. I'll see how long this tweeking lasts, but when it goes out again, I'll probably need to go ahead an order a new assembly from British Atlantic.
Just wondering-Is it really easy to install these? Any special tools involved? I don't have a jump seat so that's not an issue for me. BTW, the rug is dry and no sign of water leakage, thank goodness I don't have that problem too (sorry about yours Adam). Thanks, Michele |
Way to go Michele... Did you get both lights up and running or just one side. What about the back up lights? Or the running lights. Strange if only the brake lights go out. Did you get your tank fixed yet?
#8 (permalink) | |
The Urban Motorist
Back to the mission: The plastic that holds all the lamps together is connected with a big electrical connector that you can pry off by hand or with a little help with a flat screwdriver. You can't help but notice it when you open the hatch. Other than two functional hands, just expect to glow a little (that's sweat). For a beginner, give yourself a hour and one half. Grab the tools and bring the cooler with ice and something you like to imbibe afterwards. You need probably need to remove the lenses if you are doing a total swapout with a new set of receptacles. Inspect it first to see if you really have to replace it. I bet if you have one of those dentist tools with a curved pick or a tiny screwdriver, you can charm those connections back into submission. |
#9 (permalink) | |
I didn't check the back-up lights thank goodness, or else I might not have been alive to write you back! I'll check those with hubby tomorrow. The dealer called back about scheduling the fuel tank replacement, but he needs the truck for at least 2 1/2 hours, but they'd prefer to have it all day. I guess I can part with it now that we have our trusty Westfalia, so it'll go in on May 4th. Take care guys and thanks, Michele ![]() |
#10 (permalink) | |
4x4 Adventure Gear
Also, on the rear quarter panel (square windows) the rubber around the window cracks at the corners. Just grab some black silicone and fill in those cracks if you don't want to replace the rubber.
#11 (permalink) |
Sometimes the tail light housings get distorted from the heat of the bulb, causing the bulb holders to fit poorly. That has been my problem. I will eventually have to replace both of them. I bought a couple new bulb holders but they wouldn't fit due to the disfigurement of the tail light housing, so I will wait to use them when I get new housings. As far as access goes, on the passenger side I have a jump seat, and it is a little tight, but after I remove the access panel my 12 year-old son reaches his little arm in there and wiggles the bulb holder. He can also remove the nylon nuts that hold the light housing in if I need to take it out & "play" with it. On the drivers side, I can fit my hand in through the access in the storage area (no jump seat on that side) and take care of that one. Good luck, LRW
#12 (permalink) | |
#13 (permalink) |
Lamp Assembly - Left Hand - Rear - Directional (Amber) AMR5150G / Lamp Assembly - Right Hand - Rear - Directional (Amber) AMR5151G. Hope this helps! LRW
#14 (permalink) | |
This will help me so much and I think it will help lots of others as well. Driving around I've noticed other Land Rovers with the same problem- one brake light out. Thank you, Take care, Michele ![]() |
