Old 01-19-2007, 04:37 PM   #1 (permalink)
The Urban Motorist
Adam in NYC USA's Avatar
Question New Mystery tranny sound 96 D1
Hello from Adam in NYC.
I drive for 5 days a distance of 6 miles roundtrip.
Days off, I vary in trips from 60 miles to 350 miles roundtrip.
I have a mystery sound that has developed over the span of a week. Btw,I have a 1996 D1 with an automatic transmission.
I have developed a throbbing low frequency motorboat sound that occurs under acceleration (starting at 2000 rpm and 20 mph), also going uphill, and gets louder whenever I exceed 50 mph. Sound disappears when cruising, going level, and under deceleration.
Inspection of the tranny dipstick shows little and there is no burnt smell.. The tranny did Need a quart of ATF.
I am the 3rd owner of the D1, one with 114,600 miles and some towing in the past.
Anyone gotta a educated guess? Right now- it sounds like $2000 to me.
inert facts.
Old 01-19-2007, 08:08 PM   #2 (permalink)
96 Disco
rovermech's Avatar
Id check the u-joints.
rovermech is offline   Reply With Quote
Old 01-21-2007, 11:24 AM   #3 (permalink)
Giver of Last Rights to Fallen Rovers
Default u joints
I 2nd checking the joints, if they feel ok check the diffs, there shouldn't be more than an 1/8 to 1/4 inch play in them.
Marty
270 576 7922
Drillbit is offline   Reply With Quote
Old 01-21-2007, 04:31 PM   #4 (permalink)
beer drinking member
dent's Avatar
i'd say the rubber donut between the drive shaft and the rear diff might be falling apart. mine when and i replace with a ujoint
sam
dent is offline   Reply With Quote
Old 02-02-2007, 06:59 PM   #5 (permalink)
The Urban Motorist
sam
Had that replaced two years back/ so far the same/ time to do some OT for some tranny work.
inert facts.
Old 02-10-2007, 07:22 AM   #6 (permalink)
The Urban Motorist
Thumbs up Problem resolved.
Sometimes it is the little things that do it. Got rid of most of the noise. Will drive it some more to see if that really got rid of it.
Adam in NYC
inert facts.
Old 02-15-2007, 09:19 PM   #7 (permalink)
The Urban Motorist
Thumbs up Noise from Rims and Lugnuts Loosened by Use and Extreme Cold
Had some tires go flat in the frigid weather we are undergoing here in the Northeast. Had two tyres go flat on the left side. Had the tyres serviced and after the tyre guy did his business, the noise disappeared on the left side. Did the right side and the noise diminished greatly.
(Note: Read below, that was part of it).
inert facts.
Old 03-28-2007, 11:45 AM   #8 (permalink)
The Urban Motorist
Wink You are right but... its the bolts not the flexi
sam
You're right. The bolts looks like they are chewed on one side. The front noise turned out to be worn ball joints on the back bend tie rod next to the steering damper. The front has cost me about a bit , now to do the back flex-coupling, and I changed it just a few years back.
Huh. Thanks DAP, for the parts.
Adam in NYC
inert facts.
Old 03-28-2007, 12:49 PM   #9 (permalink)
TerryS's Avatar
Didn't sound like a xmission problem, and glad it turned out not to be. FWIW, if you ever do need transmission work, The Transmission Shop, in Coventry, Rhode Island, excellent on ZF boxes, gets about $1400 for a complete overhaul.
Old 03-30-2007, 06:43 AM   #10 (permalink)
The Urban Motorist
Wink SOLVED PROBLEM- TORN UNI_FLEX and Bend Tierod
Got my D1 working in tip-top shape, thanks to DAP and Scott Dalton my mechanic.
Lifted the D1, and the UNI-FLEX on the rear driveshaft was ripped apart. I changed it about when I got the D1 (Summer 2004?) and I am puzzled how the Uni-flex just got ripped apart.
A better description is that the metal rings from one side rip themselves loose and let themselves crash to the opposing bolts from the joining shaft (Note to myself: that was the worst description that I can do but what the heck).
Noise gone and the acceleration is back when you are hitting the gas.
SO in toto, one bend tierod from some road debris I hit (maybe I should buy that armour cover for the tierods). The roto-flex noise was covered up by the squeaking in the front.
Life with a Rover. I am beginning to think that on-road here in NYC is worse than going off-road. You should see the potholes here in the pavement. They are killers.
Adam in NYC
If this happens again, I am going to install that driveshaft kit from DAP to replace that roto-flex.
inert facts.
Old 03-30-2007, 06:45 AM   #11 (permalink)
The Urban Motorist
Thumbs up Thank you........
One for the notebook.
inert facts.
Old 03-30-2007, 07:19 AM   #12 (permalink)
Series Moderator
onslow's Avatar
Check the Viscous coupling is working as these will destoy the rubber wotsit if they are on the way out, 2 years is not the lifespan i would expect for the doughnut
Current fleet
86 90 V8 in bits
86 RR classic Under repair
94 Disco TDI 3dr ex-police 256k and still going
80" coil sprung V8 auto Trialer in progress
71 2a Trialer V8 auto,parabolics,6" shackles,power steering awesome machine
Stuff I have had at one time or another
76 S3 LWB
65 2a ex mil swb
71 2a swb safari
67 2a 1 tonne TACR
57 S1 V8 SWB
81 S3 SWB diesel
82 s3 SWB diesel
82 RR 2 dr perkins diesel
83 RR 4dr V8
84 RR 4dr V8 LPG
83 RR 4dr V8 LPG "in vogue"
88 RR gm 6.2 V8 Diesel
89 RR 3.5 mazda TDi
75 S3 LWB stationwagon
75 S3 2.6 LWB
86 110 2.5D
91 disco V8
91 disco TDi
89 disco V8
81 RR isuzu 2.8 TD
Old 04-01-2007, 07:51 AM   #13 (permalink)
The Urban Motorist
Question Had to look that up "viscous coupling"
"Viscous coupling problems. This unit apportions power between front and rear wheels … mounted in the middle of the rear propshaft, when faulty it may result in unusual rear tyre wear or IRD failure.
IRD (intermediate reduction drive) failure. This is the gearbox that supplies power to the rear wheels. This is often caused by the viscous coupling failing."
inert facts.
Old 04-01-2007, 12:08 PM   #14 (permalink)
Buddy Lee's Avatar
where exactly is the VC on a DI? I didn't even realize DI's had one.
As for the life of the roto-flex if he's got a lift that would greatly reduce the life of the roto-flex because of the increased angle of the prop shaft.
'97 Disco
Buddy Lee is offline   Reply With Quote
Old 04-06-2007, 05:17 PM   #15 (permalink)
Home of "rover" the '96 Disco 1
roverpwr's Avatar
I dont think D1's have a VC in them, its just an open differential in the transfer box till he locks it in with the lever, then its 50/50 even spilt front to back. The rear shaft on my 96 has no such item, just the parking brake drum on the back of the transfer box, ujoint, shaft then the rotoflex at the axle end. I am betting on the lift eating up the rotoflex due to the greater angularity of the prop shaft. Its time to save up for the DAP drive shaft kit Adam. Cheers Mike
1996 Discovery 1 SE7
White with tan leather
Tinted windows
Brush guards
factory fog lights
roverpwr is offline   Reply With Quote
