» Sponsors
» Sponsors
Old 10-10-2009, 12:51 PM   #1 (permalink)
Default Newbee in Saudi...engine surging
Third owner of a 91 Disco, 285,000 kilo or 177,000 miles on it, problem is that it surges when hot. Runs great in morning but afternoon and evenings it begins to surge. The first thing I did was drive to the nearest Range Rover dealer (60 miles north in the desert!) and purchased some Bosch plugs and distributor wires, replaced those. Still surged. So took it to a recommended British mechanic and he changed out the fuel filter, did a tune up...still surged. Took it back and he tore into the engine and did a complete clean-up of the fuel injectors. Runs good for a while then it returned. So, have not changed out the Fuel Pump Relay switch or VSS but plan to. The Range Rover mechanic says sometimes the coil overheats and/or altenator could be the issue but hard to believe.
Any ideas would be deeply appreciated.
sreames is offline   Reply With Quote
Old 10-10-2009, 02:40 PM   #2 (permalink)
Najman's Avatar
Smile
Hello did you relocate your ignition module :
Solihull Society – Denver, Colorado » Blog Archive » Tech: Chevy Ignition Module Install
Najman is offline   Reply With Quote
Old 10-10-2009, 11:30 PM   #3 (permalink)
Deployed OIF
ArmyRover's Avatar
the IAC valve is a possible culprit. Hi neighbor, I'm stuck in your neck of the woods for the next year.
of them." unknown quote.
(offending Austrailians since 2008)
http://www.wheelinrovers.com/
91 Range Rover Classic
89 Jaguar XJ6
The Pushrod Engine Finally Gets its Due polar General Land Rover Discussion 0 05-25-2008 10:08 PM
Any body doing electric hybrid in a LandRover? Adam in NYC USA Hybrid 54 12-23-2006 11:39 PM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 04:50 AM
Custom fabrication people.. I have a pair of turbos 02disco2 Discovery Series II 9 01-24-2006 08:53 AM
99 4.6 is superlocked and won't reset Spring Range Rover P38, Mk III and Range Rover Sport 9 12-05-2005 05:46 PM
