Old 05-14-2008, 08:28 PM   #1 (permalink)
Newbie
GCNTSi's Avatar
Default Newbie Here, In Need of a Engine 4.0 DI
Newbie needing a motor. I bought a 98 DI with some "motor noise", but had a bad rod knock 45 minutes down the highway, didn't even make it home, ended up towing it with a UHaul trailer.
So I'm in need a motor, long or short block. Or if someone can tell me a good place to buy a rebuild kit, I'll pull the motor and tear it down and have a machine shop rebuild it.
Also any help with problems that I might run into, I've pulled many motors, mostly imports, but wondering if there is tricks to be aware of.
Thanks, GCN.
-GCNTSi.
98 DI
Keep it Shiny Side Up!
GCNTSi is offline   Reply With Quote
[All] Pre 96 OBD1 Fault Codes TerryS Tech & DIY 0 01-26-2007 07:00 AM
Any body doing electric hybrid in a LandRover? Adam in NYC USA Hybrid 54 12-23-2006 10:39 PM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 03:50 AM
Custom fabrication people.. I have a pair of turbos 02disco2 Discovery Series II 9 01-24-2006 07:53 AM
99 4.6 is superlocked and won't reset Spring Range Rover P38, Mk III and Range Rover Sport 9 12-05-2005 04:46 PM
