Old 06-12-2007, 06:22 AM   #1 (permalink)
Question no 2 wheel drive
Hello I have a 96 tdi disco and in hi and low 2 wheel drive it wont go. There is just a sort of scrapping sound. In 4wd there is no probs it drives great.Does any one have info on this.
sico landy is offline   Reply With Quote
Old 06-12-2007, 06:41 AM   #2 (permalink)
I would quit driving it and have someone inspect the rear diff. Either you blew the rear diff or the axles. This is kind of common in that Rover never used a really strong diff in our trucks.
Old 06-12-2007, 06:51 AM   #3 (permalink)
what about the gear box could it have any thing to do with that
Old 06-12-2007, 06:56 AM   #4 (permalink)
Elemental's Avatar
Maybe because there isn't a 2 wheel drive option on a Disco?
Old 06-12-2007, 06:59 AM   #5 (permalink)
i ment in the unlocked position wise ass
Old 06-12-2007, 07:13 AM   #6 (permalink)
That is how Elemental feels he must participate, not much on help.
Sico,
If you start up your truck, while in High range, put your tranny in drive and look under the truck, you will see your rear drive shaft spinning, this is a good indication of a bad rear dif.
Old 06-12-2007, 07:18 AM   #7 (permalink)
Elemental's Avatar
Bad desciptions of the problem yield bad advise...
Is giving BAD advise really any help at all?
Best advise you are going to find is this.
http://www.amazon.com/gp/product/083...Fencoding=UTF8
Buy this REQUIRED TOOL. Read it, and see how the system works. Onl y when you know how something works can you properly diagnosis the concern.
If you have questions that you want cleared up, after having a basic understanding of what you are looking at.... Then ask.
Old 06-12-2007, 01:36 PM   #8 (permalink)
Roverhound's Avatar
Pleae try not to crush your head doing this. That would not be much on help.
It just doesn't matter.
