No Power to Fuel Pump, ? relay fine, no clicking noise under hood
Not getting any power to the fuel pump,replaced the pump, usually theres a clicking noise accompanying ignition mode I, im not hearing the clicking noise, any suggestions ? not getting any sort of startup when power to the starter
I have seen the alarm system kill power to the fuel pump. Try locking and unlocking the truck with the fob a few times (or whatever the proper reset sequence is, maybe someone else will chime in) and then see if it works.
No, but the immobilizer or Spider can... Cold solder joints on the pcb can cause an interruption in the multi function relay circuit.. Keeps the fuel pump from coming on...
At least that's what it did on mine.. But mine was actually immobilized I think..
Worked the next day...I reconnected the battery with the hood switch hooked up . A no no...
If you take the cover off the multi function relay. you can manually actuate relay in the fuel pump circuit and see if the pump runs.. If it does, That pretty much means the immobilizer....
Sorry John, but what do you mean by hooked up? Just curious
Thx
John C
1999 DI - 2" OME lift
1996 DI - 3" AG lift - parting out
1994 RRC LWB - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
1988 Kawasaki KLR650 - parting out
1979 Puch XK
1980 Puch Magnum MKII
1980 Puch Magnum MKII - parting out
How about the Multifunction relay in the engine compartment?
Have you checked the connectors on the ECU?
Everybody likes to blame the crank sensor, have you checked yours?
John C
1979 Puch XK
the starter initiates, i noticed i cant seem to turn off the high beam on the light switch, not getting power to the fuel pump, replaced the pump and battery, theres usually a slight subtle ticking/tapping noise before ignition thats under the hood before ignition, now thats gone, replaced closed fuel loop and coolant sensor. still no startup, just cranks. any suggestions ?
OBD II reader says Fail, cannot get it to connect. when i turn the lights on, i cant shut off the high beam either.
replaced the battery, now i have a new chime when i turn the key ? what is going on with this truck ?
Reason: typo
