Old 04-13-2008, 07:42 PM   #1 (permalink)
Default No Tachometer
Heres what I got: 1998 Discovery, bone stock, 192000 miles.
Here are my symtpoms: My tach doesn't work (or I should say doesn't work right). When I start it up, the tach moves about 1/4 of an inch above the "0" and stops. If you look real close, it seems to be vibrating or moving a little.
This is what I've done: Installed a new battery, alternator and I put a new connector on the bottom wire to the alternator. I think I read somewhere on this forum that the bottom wire or the black and white wire can effect the tach if there is a bad connection.
However, it is still not working?
marcnat is offline   Reply With Quote
Tachometer Jumping Around sgnden Range Rover Classic 5 12-05-2007 12:06 PM
Tachometer not working Brahmabullet Discovery Series I 8 01-23-2006 07:52 PM
Tachometer intermittently stops working dbrisotti Range Rover Classic 14 01-15-2006 11:57 AM
Tachometer Addition? theclay333 Series Land Rovers 3 09-21-2005 06:42 PM
Tachometer Setup Help??? Geobloke General Land Rover Discussion 1 02-03-2005 08:24 AM
