Old 01-19-2008, 03:42 PM   #1 (permalink)
Default Noisy brakes
Have 1998 Discovery Tdi, front brakes 'click' or rattle when moving, have replaced rattle springs and pins but noise continues. Guessing it is brakes as noise disappears when brake is applied, any ideas?
Bill Flyer is offline   Reply With Quote
Old 01-19-2008, 03:56 PM   #2 (permalink)
Geobloke's Avatar
Yup it sounds like your brake pads are loose fella. If they become worn (and even soem brand new pattern parts - crap manafacturing) the pads rattle around in the carrier, as you apply the brake there will be a small clonk and then it'll be silent. Lift off and the rattle will come back again.
You can try taking them out and applying some copper grease to the carrier where the pad sits, that sometimes helps. Failing that it is new pads and if you can get LR originals as they fit better!
1992 K-reg 200TDI Defender 90 (Eva)
There are a terrible lot of lies going around the world, and the worst of it is half of them are true.
Sir Winston Churchill
Geobloke is offline   Reply With Quote
Old 01-19-2008, 11:33 PM   #3 (permalink)
many thanks for your quick responce ill give your suggestions a go the brake pads were replaced about 10.000kms ago once again thanks
Old 01-20-2008, 05:29 AM   #4 (permalink)
Geobloke's Avatar
No problem. Good luck!
SQQQUUUEEEKKKYYYYY Brakes, Help!! IWANTADISCO Discovery Series II 6 11-18-2007 05:15 AM
Brakes '00 Disco II davidinsat Discovery Series II 9 02-13-2006 04:46 PM
Brakes Squealing bad jsaturnia Discovery Series II 3 01-18-2006 11:06 AM
Mushy Brakes BlueDisco General Land Rover Discussion 3 12-27-2005 07:21 PM
Upgraded Brakes Lawnmower Series Land Rovers 16 10-13-2004 03:37 PM
