Old 05-19-2006, 06:16 PM   #1 (permalink)
Question Normal Temperature?
I have a 94 discovery (3.9l V8) and the temperature needle goes up to right about halfway on easy driving, and then varies ever so slightly just above and under the halfway-mark. In heavy traffic it goes up to about 3/4ths the gauge. Just got it early this year and have never had one so I don't know where it's supposed to be - is this normal?
Thanks in advance for your help!
94Disco is offline   Reply With Quote
Old 05-19-2006, 06:25 PM   #2 (permalink)
Sounds like it is moving about a little too much.
I would suggest you check and clean the outside of the radiator, maybe look at replacing the t/stat, maybe consider going to a radiator shop and ask them about roding out the radiator to reestablish good flow.
Try those for starters.
Old 05-19-2006, 06:34 PM   #3 (permalink)
Thanks for the quick reply Disco Mike! Will do that!
So halfway is where it should stay? I've had a couple of overheats on other cars , so I've gotten quite sensitive as to where the temperature needle is.
-MD
Old 05-19-2006, 11:58 PM   #4 (permalink)
Magicly Delicious
Bene's Avatar
whatever it is, I would have it taken care of ASAP, V8 Rovers tend to be unforgiving when it comes to overheation
Kevin
1994 Discovery
Old 07-30-2006, 10:00 AM   #5 (permalink)
94 DISCO 1
Check The Fan Clutch And The Water Pump Mine Went Out And Cost....
KETJAMAICA is offline   Reply With Quote
