Old 08-30-2006, 09:22 PM   #1 (permalink)
AZROVER's Avatar
Default Oil or Grease?
I've noticed that after sitting all summer in a garage in Arizona, the swivel balls in the front are pretty dry. I was told to use LR grease specifically made for this application, but I've also read on here to use oil. So whats your opinion? and where can I get this Oil/Grease?
Is there also a place to lubricate the rear axle?
Thanks
AZROVER is offline   Reply With Quote
Old 08-31-2006, 06:34 AM   #2 (permalink)
Thanks
First of all, use the grease, it holds up better, doesn't leak as easily nd gives more protection.
As for the rear axle, as well as the front drain and replace both diff housing with 80/90W gear oil.
Old 08-31-2006, 09:22 AM   #3 (permalink)
The Best 4X4XFar
300bhp/ton's Avatar
When you say swivel, do you mean the swivel on the hub for steering??
Land Rover EP90 is what's required, but most LR's bust oil seals pretty regulary and leak oil over the rim. A few years back LR did develop a grease variant of EP90 so it didn't matter if the oil seal leaked or not.
The Best 4X4XFar
Old 08-31-2006, 01:55 PM   #4 (permalink)
AZROVER's Avatar
Thanks for the replies. yeah I'm pretty sure I meant the hub for steering, the ball that the front tire pivots on.
Old 08-31-2006, 04:55 PM   #5 (permalink)
Classic 95 SWB NAS
I posted the same question on the RRC thread; if you are gathering opinions...
Roverfriend is offline   Reply With Quote
Old 08-31-2006, 06:39 PM   #6 (permalink)
If it is an emergency, go use some gear oil, if you have time use the grease, it is far better, ask any shop.
Old 08-31-2006, 07:36 PM   #7 (permalink)
My other car is an LR
landlimo's Avatar
The most intriguing answer I've heard is to use the LR one shot grease & fill the rest of the way with Lucas Climbing Gear Lube.
Becca
Land Limo & Wilks
It doesn't have to be fun to be fun. -- Mark Twight
landlimo is offline   Reply With Quote
