Old 06-23-2006, 02:15 AM   #1 (permalink)
Biffy
Default Oil leaking from oil cap and white steam/smoke
Hi,
Just need a quick bit of advice please. Ive tried searching but can't find anything.
Last night I was out on a short journey and noticed steam or white smoke coming from under the hood. So I pulled up and had a look and oil was leaking out of the oil cap over the engine, and white steam was coming from inside when I too the cap off to take a look.
edit: the car is a 1992 200tdi and its done 60k miles.
I now know the oil level was dangerously low, and i'm topping it up later, but is there anything else that could be wrong?
Cheers
Biff.
biffsmash is offline   Reply With Quote
Old 06-23-2006, 05:43 AM   #2 (permalink)
You have at least a bad head gasket and possibly a cracked head. What ever you do, don't drive it any more untill you can have a mechanic look at it.
Old 06-23-2006, 05:50 AM   #3 (permalink)
Biffy
Hiya cheers for the reply
Its been in a garage for work as I crashed it back in april, but they have given it a clean bill of health.
That sounds bad Can't afford to sort out head gasket problems right now. Im not mechanically minded and the garage thats been sorting it for me told me the car is in exellent condition.
Well I hope its not as bad as it sounds, but I appreciate the advice. The guys from the garage are coming to look at it tonight so i'll get the bad news then.
Biff.
Old 06-23-2006, 06:15 AM   #4 (permalink)
The Best 4X4XFar
300bhp/ton's Avatar
I doubt it's a cracked head, would be very rare on a TDI.
You really need to find out if it was smoke or steam as there's a subtle but fundamental difference.
White smoke would normally indicate a turbo failure, but that smoke wouldn't normally be coming out of the oil filler cap.
If you have steam in the rocker cover then it would indicate a cylinder head casket or craked head (but I still think it's unlikley).
As long as you didn't over heat the engine it should be ok.
If it is a cylinder head gasket you'd get a "mayonase" (sp?) white substance around the oil filler.
Also check for contaminents in the coolant in the header tank.
TDi's are generally pretty bullet proof and rarley need any ore than regular maintance before 150-200k miles.
But I agree get a mechanic to look it over.
If you need any bits give me a shout (or PM) I'm not far from Luton. I've just finished an engine swap in my 200Tdi Discovery. I have a spare turbo, injector pump, cylinder head, intake manifold (with new gasket), rocker cover (new seal) all sitting on the shelf.
Condition is "used" on all the items, but as far as I know they where working when I took them off my old engine, I'm not looking for much for them, just really want shot of them.
The Best 4X4XFar
Old 06-23-2006, 06:36 AM   #5 (permalink)
Biffy
Heya
The Engine, even while i was driving it, was cool, the guage was showing as cold as it could get. Theres no white substance around the filler cap.
The garage that did all the services are suggesting that a breather pipe may be blocked, I am sooo hoping that might be the case but i'm not holding my breath.
Anyway i'll keep all that in mind and appreciate all your help and advice
Biff
