P1316 Misfire Help!! - Page 3 - Land Rover Forums : Land Rover and Range Rover Forum
post #31 of 35 (permalink) Old 08-07-2010, 09:06 PM
Quoted: 0 Post(s)
well i should just post this for other people to see who may have the same problem, when hot the fuel pressure was 18 psi tested by land rover. bad fuel pump, havnt got it replaced yet but ill post if it worked or not
LewisTheTurtle is offline
post #32 of 35 (permalink) Old 08-24-2014, 09:11 AM
Quoted: 0 Post(s)
i have a 1997 disco with 193k. just got this p1316 while i was on the interstate. as well i have the p1317. rough road abs fault. no real loss of power but i can smell raw unburnt fuel. do i have a bad wheel speed sensor???? is that while my rover is misfiring? if i test the sensors with the omes setting what should they read at??
dustan is offline
post #33 of 35 (permalink) Old 08-24-2014, 09:23 AM
Quoted: 0 Post(s)
discooo mike!!!! help. please. i have a P1316 misfire excessive emissions and a P1317. this happened out of nowhere on the highway. came to a stop after exiting the highway and turned to pull up to the red light. i then noticed my truck was running rough and rocking. got it to my destination and the light came on. cel displaying these codes. as well as some others but when i did plug wires and a new set of plugs they havent come back yet. havent driven it much dont want to harm my rover. so they may come back. one i believe was a p0300 if that helps.
dustan is offline
post #34 of 35 (permalink) Old 08-02-2016, 10:01 AM
Quoted: 0 Post(s)
Cool was it a bad fuel pump lewistheturtle
Hi i have the same problem p1316. when i fill the truck up at the gas station the fuel pump doesn't prime and the truck wont start. The other day the truck stalled out on the road for the first time. it didnt want to start because the fuel pump wasn't priming. sometime the fuel pump primes and sometimes it doesn't. could it be a bad pump? thanks.
mr4x4 is offline
post #35 of 35 (permalink) Old 12-16-2016, 07:33 PM
ark
99 Disco I
Quoted: 0 Post(s)
I had a similar issue with a 98 disco 1. First, I wasn't using high octane fuel. Second, I changed the spark plugs and had two cylinders mixed up. Third, one of the new spark plugs I put in was faulty and leaking current. If I ran the engine in the dark, I could see an arc between the wire and exhaust. Changed that plug and it ran great.
ark is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
misfire issues inhUMaine Discovery Series I 4 12-12-2009 07:20 AM
Cylinder#6 Misfire & Coolant Leak tskim2024 Discovery Series II 6 07-09-2009 11:41 AM
Misfire cyl 4 plastic Discovery Series II 13 04-10-2007 01:58 PM
Multiple cylinder misfire code?? JAYMONEY Discovery Series II 5 02-25-2007 12:09 PM
Multiple misfire superpowerdave Discovery Series II 5 10-25-2006 01:49 PM
You may post new threads
You may post replies
