Parking Brake Cable Replacement - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 11-24-2012, 12:01 PM   #1 (permalink)
Throwing Money at It
Default Parking Brake Cable Replacement
If nothing else, I always come to you guys with interesting stories. That said...
So a couple months ago, I'm driving home from work at about 3AM, roads are dead, etc. I'm doing about 65MPH on a highway, coming up on an intersection. The light turns green, I glance both ways, looks clear, so I hit the gas, and head through the intersection. About the time I'm 150 feet short of the light, some fool in a beat up old Camaro flies through the red light, and I'm about to T-Bone him. I stood on the brakes as hard as I could, and the truck braked surprisingly well for its weight/age, and I didn't hit him. However, while standing on the brakes, something "gave" in the pedal. I get to the next intersection, and go to hit the brakes, pedal goes straight to the floor. I drove the rest of the way home with only my parking brake working, so every time I'd come up to a stop, I'd just use the parking brake to slow down/stop. Worked quite well. I got home, and the next day replaced my right rear caliper, which had split completely in half, then kinda turned into powder.
So fast forward a couple months. I pulled up to a friend's house for a night of drinking, and turned the truck off, and yanked the parking-brake lever up. Problem is, the lever went up with no resisitance and broke a chunk off the center console. So, I'm assuming the parking brake cable broke. I've searched the forum for the last 20 minutes, and I can't find anything on replacing it. I also checked the Rave manual, and didn't get anywhere in there. Sooo... does anybody have a parking brake cable replacement thread/walkthrough?
Tacticool is offline   Reply With Quote
Old 11-24-2012, 07:21 PM   #2 (permalink)
Spike555's Avatar
Great story, I got nothing to help though.
2nd owner of a '97 Disco with a ARB winch bumper, SD roof rack, Rover Racks ladder, Cooper S/T's and 220,000 miles on the clock and still a daily driver.
Spike555 is offline   Reply With Quote
Old 11-24-2012, 09:42 PM   #3 (permalink)
roverandom's Avatar
You don't really need a walk through to replace the hand brake cable. It's very straight forward, especially if you get one from a wrecker where you can pull the part out yourself as you get to practice. The hardest part is not wrecking the ultra flimsy plastic console, but seeing as it's already broken........
The brake cable comes up through a rubber grommet (integral to the cable IIRC) to the hand brake leaver. Remove the pin holding the cable end to the leaver, pull the cable from underneath and through the floor. Remove cable from parking brake drum end as per service manual. IIRC there are two retaining clips that secure the cable at points along the T'case. Reverse to install.
"Your only supposed to blow the BLOODY DOORS OFF" Charlie Croaker. The Italian Job. 1969.
Matt.
roverandom is offline   Reply With Quote
Old 11-25-2012, 03:11 PM   #4 (permalink)
Thanks. I try.
I checked my service manual, and I can't find that in there anywhere, I'll probably tackle it this coming weekend, but anything I need to know about that bit?
Old 11-26-2012, 05:01 AM   #5 (permalink)
ihscouts's Avatar
Since there's so little about it in the Rave other than adjustment I can't imagine it being anything harder than for instance changing spark plugs. While your in the parking brake you might want to change out the shoes, probably the most overlooked maintenance item on any Rover.
97 SD - Altai Silver.
75 Triumph TR7 FHC - French Blue.
ihscouts is offline   Reply With Quote
parking brake cable help klaasjoe Discovery Series II 2 12-23-2009 11:38 AM
Hand Brake Cable freddiesax Discovery Series II 0 10-14-2008 02:49 PM
hand brake cable replacement... atvsmurf Range Rover Classic 0 12-21-2007 09:49 AM
Kickdown Cable replacement mll Range Rover Classic 1 07-20-2007 07:00 AM
'87 Range Rover Kickdown Cable replacement 9dawgs Range Rover Classic 1 11-23-2005 11:25 AM
SEO by vBSEO 3.3.2
