Old 04-26-2006, 05:48 PM   #1 (permalink)
Default pcv question
been reading all the threads on cleaning maf,steppor motor,has helped alot{used carb/choke cleaner}.found seafoam in the spray can and put the whole can in today {in tps hose,didn't smoke alot,so I guess I;m clean}I took the plenum hose off and there was carbon on it so cleaned with carb cleaner.does that piece come out of the valve cover?don't want to break anything and have it fall into the valve assembly!btw,seafoam in an aerosol can brilliant.does this plug in the valve pipe come out and what's the best way to remove and clean.can I get a replacement locally,hoses are good.appreciate all the great info,truck runs a whole lot better!!
rjlsierra is offline   Reply With Quote
Old 04-26-2006, 05:53 PM   #2 (permalink)
You don't use the spray version of sea foam when trying to do an induction cleaning. By 3 bottles, one for the gas tank, one for the crank case with a fresh oil change and the other can get sucked slowly over about 2 minutes into the engine, then shut it down for 30 minute. After 30 minutes be prepared to make 20 minutews of smoke and don't stop till the engine quits smoking.
By the way, the SaeFoam sprat is good to use to clean the throttle body.
Old 04-26-2006, 06:07 PM   #3 (permalink)
Default thanks for replying
It took me awhile to empty the can and while it didn't billow smoke there still was some so I think it helped,I could tell by the idle almost stalling so I let up and then resumed spraying .what about the pcv,do I just yank that thing out,clean and put back?this one's for you dmike
Old 04-26-2006, 06:29 PM   #4 (permalink)
The whole idea is to soak the carbon on the valves with lots of fluid over 2 minutes and the shut off the engine to let it chemicaly do its thing.
Yes, pull and clean the pcv.
Old 04-26-2006, 08:05 PM   #5 (permalink)
At least the landie got her first taste of seafoam,I did let her soak for a good 1/2 hour.next time I'll use the bottle {although I use similar products to de-carb my outboards and they all work well}can you get replacement pcv valve's locally for our trucks {Iasked dis/auto and they couldn't help}Excellent info any diy'er can really improve performance on their truck just by reading all these good threads.thanks again dmike
Old 04-27-2006, 06:14 AM   #6 (permalink)
Locally depends on where you live.
Old 04-27-2006, 11:39 AM   #7 (permalink)
LANDY96's Avatar
Do you leave the SeaFoam in the Crankcase with the fresh oil change, or change the oil again soon after you clean the intake? Thanks!
When I change oil, it doesn't take long for the oil to get darker. I do run synthethic oil through it as well. Thanks for any info.
Eric The Red
93 Range Rover Classic
96 DISCO SE7 5-SPEED SOLD
96 DISCO SD 5-SPEED
-ARB Bumper
-OME 2" Lift
-2" spacers
-Safari snorkel
-15" steelies
Old 04-27-2006, 12:31 PM   #8 (permalink)
I would say to leave the SeaFoam in the crank case till it gets dark, which may only take 1000 miles.
If you have a problem with dirty oil, consider flushing the engine before your next oil change. There are many products at the parts store to do this with, most are a quart and take 10 minutes of idling to di their job. For my driving, I flush my engine every 10,000 miles, it then stays cleaner alot longer.
Old 04-27-2006, 05:41 PM   #9 (permalink)
Default seafoam in oil&gas
I ran seafoam in the oil and gas for about 400mi before changing and it does absorb alot of sludge when you drain,not sure if you should go the full 3000.you will notice a difference.
Old 04-27-2006, 06:06 PM   #10 (permalink)
Default Seafoam in a V8i aluminum block?
DiscoMike..
Is seafoam safe to use in my cast aluminum block (or are all LR blocks aluminum)? Thanks.
Wade
wade is offline   Reply With Quote
Old 04-27-2006, 09:09 PM   #11 (permalink)
pavel's Avatar
Gentlemen: exactly where do you pour that 3rd can of SeaFoam into the engine? I've used 'combustion chamber cleaner' on carb engines but never on a FI engine... On carb engines, I usually pour it directly down the carb while the Mrs. keeps her going. At the 3/4 mark of the can, I pour it in fast and kill the engine, then wait 20 minutes and then restart.
Old 05-13-2006, 05:20 PM   #12 (permalink)
damn ... i only bought one can. where does the third can go
donsdisco is offline   Reply With Quote
Old 05-13-2006, 05:46 PM   #13 (permalink)
One in the gas tank, one in the crank case and one thru the induction system into the manifold and thru the valves.
