#61 (permalink) | |
![]() And it will took me a long long time to put it bake together, but I think you know more than I do. How ever long you think it will take x 3.
Kevin 88 RRC "Audrey" |
#62 (permalink) |
hmm im considering this, shouldnt you get new lifters as well when you get a new cam? thanks for the input guys.
oh and shop said heads were way over heated, i burned the oil on them, and basically they were very impressed. but they said they would call when they are done of if there is a problem (crack ect.) and i have no call yet, should ge the call tomorrow saying they are done if all goes well. |
#64 (permalink) | |
My D&D cam cam with Crower lifters, but I think they may be the source of my noise (I have heard they were noisy before).
Ron Paul: The most Constitutional “Bang for the Buck” you’re going to get. www.ronpaul2008.com www.mvlrs.com |
#65 (permalink) | |
Banned
#66 (permalink) |
heads done today woo hoo. not putting it together this weekend cause i think im going to get the cam and lifters and do i need pushrods too? also hank you had said 258 or 260 i think, which do you suggest? and i know the oil pump is in the front cover, but should i replace that while im in here? or do they not go out? or what do you guys think? thanks as always!
#71 (permalink) | |
If you are going to replace the cam, refit the new one with some assembly oil, or STP, and be VERY carefull when putting the cam in as cam bearings are very soft and easily scored. Make sure everything is spotlessly clean. Always replace lifters when replacing a cam. If you're going with a performance cam with extra lift, be sure the lift doesn't exceed the spring compression dimention, and also consider roller rockers. |
#72 (permalink) |
Ian Matthews
If you are pulling the oil pump apart, make sure that you mark where the gears meet before letting them fall out. If you do not match them up the same as they came apart you will lose oil pressure as the surfaces have mated together. To will most likely find that if you did not mark them that you will need new gears.
Agree with Terry about using a drill to get the oil through the motor before starting it. Run the drill for around 5 minutes before starting. |
#73 (permalink) |
thanks guys, if the general concensus is that its tough and doesnt need to be messed with then id much rather leave it alone. right now im deciding if i should leave the bottom end as is and put it back together, or if i should get it honed out and new rings. opinions??? i did get my heads in last friday, here are some before and after pics. they were warped and the shop said they were extremely overheated. burned the oil on them
before ![]() ![]() ![]() after ![]() ![]() |
#74 (permalink) |
Wow...that is a thing of beauty!
JC... 1996 Discovery SE - The Blue Marlin - gone =( 1965 Series IIa 109 RHD Dsl - Wilks www.TerraTrekker.com
#75 (permalink) |
on, off, on, off, on...
Well, it's almost been a year. How is she running? Give us some feedback already!
03 Disco w/CDL 95 Disco 98 Disco: my first (gone) |
