Old 06-11-2006, 02:36 AM   #1 (permalink)
Joe Beierly
oberdahill's Avatar
Default Plastic Radiator nut
The plastic nut on top of the radiator separated and I want to replace with the copper. What size do I get? I leave on Tuesday morning for the right coast and will be there for a couple of days. Is it a Home depot thing? I don't have time to go to the German LR dealership. How do I get the remaining plastic out without dropping too much into the radiator?
Joe
96 D1 SE7
95 Volvo 850 Turbo
98 Chevy S-10
Pearl City, Hawaii
oberdahill is offline   Reply With Quote
Old 06-11-2006, 09:13 AM   #2 (permalink)
Aaron98Disco's Avatar
You probably won't have the time to order one but I just saw these for sale online.. either DAP or AB. I think.. Also they might have been brass.. not copper.
Current: 1998 D1
Ex: 1992 RRC (long gone)
Aaron98Disco is offline   Reply With Quote
Old 06-11-2006, 09:43 AM   #3 (permalink)
Wheeler
SCSL's Avatar
If I understand your question correctly, I had a similar problem w/ my stock plastic diff drain plug bolt. I used a utility knife to get a grip on the broken plastic & unscrewed it.
Don't know if you have a DI or DII but the diff drain plug bolt on a DII is the same size as the radiator bolt on a DI. (Not sure about the drain plug bolt on the DI,,,may also be the same?).
Old 06-11-2006, 11:33 AM   #4 (permalink)
if you get it out try a german hardware store, its possible the thread pitch is the same and then get a brass fitting with a brass cap.
Old 06-11-2006, 01:33 PM   #5 (permalink)
Magicly Delicious
Bene's Avatar
x2 on using some sort of blade. use a knife, a large flat tip screwdriver, or something like that.
Kevin
1994 Discovery
Old 06-11-2006, 01:50 PM   #6 (permalink)
Joe Beierly
oberdahill's Avatar
Thanks for the replies. I'll hit the dealer in the morning and get a replacement, then order a brass one and have it sent out. I need to get it driveable by tomorrow.
Joe
96 D1 SE7
95 Volvo 850 Turbo
98 Chevy S-10
Pearl City, Hawaii
Old 06-11-2006, 11:43 PM   #7 (permalink)
Joe Beierly
oberdahill's Avatar
Removed most of the threaded portion of the radiator nut. While tapping it out, a large piece (about the size of the top of a soda bottle cap) fell into the radiator.
Is it safe enough to drive it to the shop to have the radiator drained or do you think I should drain it where it sits to try and get the piece out? I don't know if it fell down to the bottom where the hose is or it's stuck where it won't restrict flow. I hesitate to drive it now because the piece might get lodged somewhere in the motor.
Oberdahill
96 D1 SE7
94 Volvo 850
Stuttgart, Germany
Joe
96 D1 SE7
95 Volvo 850 Turbo
98 Chevy S-10
Pearl City, Hawaii
Old 06-12-2006, 12:12 AM   #8 (permalink)
Discomania I
edthediscoman's Avatar
Ah sugar....I would drop the main hose off the bottom of the water pump, pull it swiftly off after loosening the clamp, and drain it all to a bucket, then see if you got the piece. If not, run water from the top hose through the radiator till you do.
I would not drive it as the motor passageways are small, and you have to go through the water pump too...and thats not cheap.
Ed
edthediscoman is offline   Reply With Quote
Old 06-12-2006, 12:21 AM   #9 (permalink)
Joe Beierly
oberdahill's Avatar
Ed,
That's what the plan is for this morning. Hopefully the piece will drop out easily. It needed a coolant change anyhow.
Joe
96 D1 SE7
95 Volvo 850 Turbo
98 Chevy S-10
Pearl City, Hawaii
Old 06-12-2006, 12:49 AM   #10 (permalink)
Discomania I
Good luck!!!...cause it won't melt....its designed for high temp.
Ed
Old 06-12-2006, 01:35 AM   #11 (permalink)
Joe Beierly
oberdahill's Avatar
Ed,
Your suggestion worked great. The piece came out with the remaining coolant. Now to find some distilled water and give it a fill.
Joe
96 D1 SE7
95 Volvo 850 Turbo
98 Chevy S-10
Pearl City, Hawaii
Old 06-18-2006, 10:08 PM   #12 (permalink)
For future reference.......put a paper towel into the hole where the nut was to catch the remaining plastic pieces. Then use a shop vac to pull it out. Also, just had to replace mine......found a threaded copper plug at auto parts store. It is a common part.
Howard
95 D1
Howard is offline   Reply With Quote
Old 06-19-2006, 09:47 AM   #13 (permalink)
If any of you want to buy one of the brass plugs go to Expedition Exchange, that is where I bought mine for my diffs.
