Old 07-18-2005, 07:14 AM   #1 (permalink)
Default platinum plus 4 plugs
wouldn't mind hearing some feedback on these.My truck has the regular oe plugs and runs fine but since I put a k&n + a tornado {other than faster revs,not sure on the benefit!but still testing} I thought it might enhance the idling,thanks in advance,RJ
rjlsierra is offline   Reply With Quote
Old 07-18-2005, 07:16 AM   #2 (permalink)
4x4 Adventure Gear
John C's Avatar
It will help for a few months, then they start to fail. Stick with the stock plugs, avoid the Plat 4.
John C
1996 DI - 3" AG lift
1990 Kawasaki KL650B Tengai
1989 Kawasaki KLR650
Old 07-18-2005, 07:30 AM   #3 (permalink)
Elephantitis penisitis
Never had a problem with them. I guess, like they say, every rover is different, so the response you are going to get from your truck will be different from others.
Old 07-18-2005, 08:37 AM   #4 (permalink)
LANDY96's Avatar
I have had them in for 10k. No problems. But no added benifits either. It will just be a long time before I will have to change them.
Eric The Red
93 Range Rover Classic
96 DISCO SE7 5-SPEED SOLD
96 DISCO SD 5-SPEED
-ARB Bumper
-OME 2" Lift
-2" spacers
-Safari snorkel
-15" steelies
Old 07-18-2005, 09:32 AM   #5 (permalink)
PCrover's Avatar
I read some where that the plus four's need a higher coil voltage than the stock D1 has to offer and that is why they can fail so quickly. If you do an ignitian upgrade, they should be fine. This info comes from others, not my personal experiance.
Gary
2001 Discovery II
PCrover is offline   Reply With Quote
