Old 06-17-2007, 09:03 PM   #1 (permalink)
hunkslam's Avatar
Default plug diagram
ok, im going to remove and clean and check the wires of my ignition coils to hopfully repair the P1316 code.... i need the wiring layout so i dont mess things up when i put back together... 96 disco 4.0
O&A PARTY ROCKS!!! XM 202
hunkslam is offline   Reply With Quote
Old 06-18-2007, 06:28 AM   #2 (permalink)
How many miles on your current wires, how about the plugs?
I wouldn't jump into pulling and cleaning the plug wires if they are very old, chances are you will damage one or two in the process of removing them.
What brand of wire are you using?
Old 06-18-2007, 03:32 PM   #3 (permalink)
hunkslam's Avatar
i just replaced the wires, not even 10miles on em. i know the order sequence is on the coil pack but whats the order on the cylinders?
Old 06-22-2007, 08:49 AM   #4 (permalink)
96discose7's Avatar
front left engine is #1 front Right is #2 ....... etc
96discose7 is offline   Reply With Quote
Old 06-22-2007, 03:34 PM   #5 (permalink)
hunkslam's Avatar
ok, removed and cleaned coil pack, checked wires, all looks great. the truck still running poorly, i come to a stop and it wants to die, ive played with the idle knob, but still no go, check engin light still on same code, P1316, ive cleaned all electrical parts, new oil, full gas tank, everything is like it should be, but still, what else o i try????
Old 06-25-2007, 06:46 PM   #6 (permalink)
hows the fuel pressure. I would check to make sure it isnt bleeding down by an injector staying open.
you need to check pressure it should be around 32-36 psi. also when you turn off the key the pressure should hold for twenty minutes. if it drops you got a problem.
