Old 03-07-2007, 11:12 AM   #1 (permalink)
Default poorly disco
hi can anyone help,my 3.9 disco lpg is poorly at the moment,recently changed the plugs,leads etc and it ran fine for about 25 miles then developed a serious misfire and loss of power,now it starts fine when cold but after a few mins ticking over starts to misfire when revved,once i get it revving it seems sweet,this happens on either petrol or lpg but worse on lpg,took it for a drive seems to run ok as long as revs kept up,but a bit arkward being an auto,thanks in anticipation,Mark
markrhardy is offline   Reply With Quote
Old 03-07-2007, 12:28 PM   #2 (permalink)
What brand of spark plugs and wires did you install?
Are you sure you didn't crack a plug or damage a wire when installing them?
Old 03-07-2007, 12:47 PM   #3 (permalink)
Question
Hi thanks for your reply,used bosch super 4 plugs and silicone 8mm leads as sugested by local auto suppliers,thought that may have been problem and have tried new all round but problem the same,someone sugested the ignition amplifier/coil/distributor pick up/head gasket/porous head etcbut would be expensive to keep on changing things,hoping someone had had a similar problem,thanks again,Mark
Old 03-07-2007, 12:50 PM   #4 (permalink)
singingcamel
singingcamel's Avatar
make sure your plug wires are on snug,both on the plugs as well as the coil.check your leads for correct position in the firing order.
i recommend ome cap and rotor..did it run poorly before the tune up?
singingcamel is offline   Reply With Quote
Old 03-07-2007, 01:16 PM   #5 (permalink)
Elemental's Avatar
I knew it!
Throw that shit away and put in the CORRECT spark plug!
Old 03-07-2007, 01:59 PM   #6 (permalink)
HI,thanks again,two things was running ok before tune up,used to pop back now and again when on lpg but as a rule ok,and which plugs do you recommend,cheers,Mark
Old 03-07-2007, 02:01 PM   #7 (permalink)
Elemental's Avatar
Champions... Copper ones, just like what came from the factory.
Old 03-07-2007, 02:02 PM   #8 (permalink)
will buy some tomorrow,thanks
