Old 12-28-2006, 08:59 AM   #1 (permalink)
timkel74@msn.com's Avatar
Default Power steering fluid???
My 97 D1 seems to be very low on power steering fluid. Also, has that whining noise when you turn the steering wheel. Was about to just put in regular power steering fluid and figured I would check with you all before I do anything.
Any suggestions???
timkel74@msn.com is offline   Reply With Quote
Old 12-28-2006, 09:58 AM   #2 (permalink)
LRDisco94's Avatar
I heard from mechanic just to use reg fluid
-LRDisco94-
www.floridalandroverclub.com
LRDisco94 is offline   Reply With Quote
Old 12-28-2006, 10:03 AM   #3 (permalink)
I would suggest you drain out the old burned fluid replacing it with one bottle of Lucas power steering additive and Vavoline's synthetic power steering fluid. It should quiet down your punp and give you many more years of use.
Old 12-28-2006, 10:13 AM   #4 (permalink)
k12
k12's Avatar
My D1s take automatic transmission fluid for power steering. Not sure on D2s.
k12 is offline   Reply With Quote
Old 12-28-2006, 11:16 AM   #5 (permalink)
Support Our Troops
apbtpetey's Avatar
I would take a look for cracks/holes in the lines and change them out if they are leaking. Then I would use the synthetic fluid like Disco Mike stated.
John Conklin
LRO Moderator
apbtpetey is offline   Reply With Quote
Old 12-28-2006, 05:28 PM   #6 (permalink)
before you put in the synthetic, top off the fluid if there is leaks
if the box and the lines are leaking then keep it filled with atf fluid until you get a chance to fix it.
if its filled and its till making noise especially after you turn the wheels a few times and run the vehicle then try what mike said. it should do the job until you get it fixed.
Old 12-29-2006, 03:44 AM   #7 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
X2!
Read your owners manual and/or the LR shop manual!
1997 Disco 1
2000 Disco 2
1989 RR(gone but not forgotten )
Miami Valley Land Rover Society
www.mvlrs.com
ON WISCONSIN
Old 12-29-2006, 04:51 AM   #8 (permalink)
D2's take power steering fluid by the manual.
Old 12-29-2006, 12:57 PM   #9 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
D1's take trans. fluid.
1997 Disco 1
2000 Disco 2
www.mvlrs.com
ON WISCONSIN
Old 12-29-2006, 05:39 PM   #10 (permalink)
its actually ACE fluid. Active cornering enhancement fluid. its greenish when its new.
Old 12-30-2006, 05:23 AM   #11 (permalink)
A quote from the owners manual,
" Texaco Cold Climate PAS fluid 14315 or GM Part # 12345866, 12345867 amber appearence".
When either of these is not available, I have found that Vavoline's synthetic power steering fluid works well in bothe th power steering and the ACE.
Old 12-30-2006, 09:24 AM   #12 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
Mike's right, checked the manual in my wifes truck and the RAVE both say exactly what Mike says above for the D2. D1 is ATF. Mike are you sure you were never a LR "tech" to have figured that one out?
1997 Disco 1
2000 Disco 2
www.mvlrs.com
ON WISCONSIN
Old 12-30-2006, 09:28 AM   #13 (permalink)
Between being a service manager and a writer, you pick up alot of little tid bits along the way. My concern is I think I am loosing more of then gaining any more.
OH WELL, have a good New Years.
Old 04-08-2008, 09:02 AM   #14 (permalink)
Going to replace ACE fluid. I understand that I should remove old, dilute, run, and repeat until fluid is clear. I have an '01 Disco II. I am going to use Valvoline Synthetic Power Steering Fluid. Is this correct?
If I also do the power steering fluid, I should add 1 bottle Lucas power steering additive in the power steering reservior with the Valvoline synth, and keep levels at max, correct? Do I use the same process of removing old and diluting, as in the ACE procedure?
Want to do this right.
discoma is offline   Reply With Quote
Old 04-08-2008, 09:53 AM   #15 (permalink)
Elemental's Avatar
http://carsoft.co.il/Forum/other/Lan...%20Service.htm
The right way to do it is use the correct fluid for the application. Anything else is a maybe it will work/maybe not.
