Old 05-25-2008, 01:35 PM   #1 (permalink)
Default power steering pump check
A few days ago my 94 disco 300tdi started to make a metallic squealing noise when pulling away now the squeal has gone but the steering wheel and dashboard vibrate quite violently when accelerating in 2nd and 3rd. The belt was replaced 6000 miles ago and is still in pretty good condition so i suspect the power steering pump is on its way out.
If my diagnosis sounds right then how can I inspect the pump, preferably without removing it from the car? If my diagnosis is wrong what else should I be looking for?
jimllshiftit is offline   Reply With Quote
Power Steering Pump Problems??? williampdx Discovery Series I 7 10-18-2007 10:11 AM
Crazy Power Steering Pump!! ChuckD Discovery Series II 4 02-05-2007 09:26 AM
power steering pump drum655 Discovery Series II 16 04-13-2006 12:50 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 02:18 PM
Intermittent Driveline Vibration at 60MPH AdrianL Range Rover Classic 10 06-24-2005 08:52 AM
