» Sponsors
» Sponsors
Old 04-06-2008, 08:00 PM   #1 (permalink)
Default Pressure Wash under hood
New owner of a very used 1998 Disco. Previous owner neglected a leaky valve cover and oil was everywhere. Got the gaskets changed, but wanted to clean the oil off the engine and compartment. Drove it to a local car wash and used high pressure to clean under the hood. I went to start it up, it ran for about 3 sec and cut off. Can't get it to start at all. Turns over, just sounds like it has no fire. Help.
marcnat is offline   Reply With Quote
Old 04-06-2008, 08:06 PM   #2 (permalink)
Deployed OIF
ArmyRover's Avatar
something in your ignition system got wet. Once it dries out it'll probably be fine.
Pressure washing under the hood usually leads to this.
of them." unknown quote.
(offending Austrailians since 2008)
http://www.wheelinrovers.com/
91 Range Rover Classic
89 Jaguar XJ6
Old 04-06-2008, 08:13 PM   #3 (permalink)
I am in South Carolina where the high today was 81. I washed it around noon, and I figured that I probably got something wet. I pushed it to a parking lot where there was a lot of sun hoping that heat genterated would dry it out. Do you think it would take longer?
Old 04-06-2008, 08:20 PM   #4 (permalink)
Reptile Expert
no idea dude...don't pressure wash your engine, unless you're doing a rebuild in your driveway and are taking the whole thing apart...
a damp rag + a drying rag and a little hands on wiping will do the job everytime. you can be as delicate and as rough as you need to be by hand to clean an engine bay.
04 D2
stolenheron is offline   Reply With Quote
Old 04-06-2008, 11:10 PM   #5 (permalink)
repete's Avatar
on my Range, I learned this the hard way. for me I found that there is a signal wire on the coil to let the ecm open the fuel when spark is present. on my Classic I think it was a black wire with white stripe. whenever p/washing now, I always avoid the dist and the coil.
repete is offline   Reply With Quote
Old 04-07-2008, 09:45 AM   #6 (permalink)
Administrator
A D1, unlike a D2 can be washed but you have to stay way from the ECU, get it wet and it may be days before it is dry enoughtto restart. Don't force it to start, let the ECU dry out then you should be fine.
For the D2's, they love water, I power scrub mine after every trail with no side effects.
Old 04-07-2008, 11:38 AM   #7 (permalink)
Default Thanks for the help
The Disco started today!! Lesson learned.....don't pressure wash the motor
Detailing 101: Common Question and Answers, What and Where to buy stuff + Technique David General Land Rover Discussion 59 11-23-2009 08:38 AM
No Oil Pressure oil light on ? =/ tjrovertech Range Rover Classic 2 02-20-2008 03:02 PM
P38 Fuel Pressure & Code P1179 ikoinu Range Rover P38, Mk III and Range Rover Sport 6 02-18-2007 04:02 PM
[ALL] Detailing FAQ's + Technique Disco Tech & DIY 0 01-08-2007 04:31 AM
My hood almost killed me...Need Help! RageRover Range Rover Classic 21 01-23-2006 08:22 PM
SEO by vBSEO 3.3.2
