Support Our Troops
okay my 97 disco has thrown a new problem at me.
the first time this has happen was this afternoon when I was running late. I go out to the Disco and turn the key and nothing happened not even a single noise. Try to start it again and it trys to turn over, but did doesn't, after 3 tries it turned over and ran fine. Got to where I had to go. Disco sat for about 1 hour. Try to start it and it wanted to turn over, but didn't. Started right up on the second try. Drove down the road. It sat for about a nother hour and when I went to start it this time it started right up like nothing happened. Any clues on where to start looking????????
John Conklin LRO Moderator |
#2 (permalink) | |
4x4 Adventure Gear
If the vehicle is not in Park it will not turn the engine/starter. It happens to my 96 sometimes and all I do is push the shifter all the way forward. Good luck.
John C 1996 DI - 3" AG lift 1995 DI - Scorpion Racing Extreme Kit 1991 RR - parting out (few parts left) 1990 Kawasaki KL650B Tengai 1989 Kawasaki KLR650 |
Sounds like you are about to go buy a battery. I would suggest you go to your favorite shop and have them charge and then do a load test on your battery and alternator. Also check all your grounds and connections for loose or dirty connections.
Mike |
#4 (permalink) | |
Support Our Troops
![]() Really though I would have never thought of it not being in park all the way. In addition I am sure I am due for a battery soon and will look into that as well. Anybody have any thoughts on the best battery to get for the Discovery?
#5 (permalink) | |
As for the battery, if you go wheeling alot, go for a gel tytpe battery like a Optium Red or Yellow top, they will take alot more abuse the a Die Harder. Mike |
4x4 Adventure Gear
Now that Mike mentioned the battery, is it possible that the terminals on your battery are dirty? Have you cleaned them recently? Just a thought.
