Proper Oil Change procedure - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 21 (permalink) Old 01-16-2009, 11:56 AM Thread Starter
Quoted: 0 Post(s)
This gives away the true extent of my ignorance, but I've got to learn somehow...
I've read the posts -- everyone has a different method for changing the oil on this puppy, but no-one lists the procedure beginning to end. Do I:
1) Drain sump, remove filter, fit new filter (filled with new oil), fill sump with new oil;
2) Remove filter, fit new filter (filled with new oil), drain sump, fill sump with new oil;
3) Drain sump, fill sump with new oil, remove filter, fit new filter (filled with new oil);
4) Take it to JiffyLube.
Enlighten me, please! I promise you'll only have to do it once (regarding oil changes, anyway)...
Thanks!
Ben
Benobo is offline
post #2 of 21 (permalink) Old 01-16-2009, 12:13 PM
Elemental's Avatar
Quoted: 0 Post(s)
Use a ACEA rated oil.
If I had to pick, I say 3 is the safetst.
Elemental is offline
post #3 of 21 (permalink) Old 01-16-2009, 01:18 PM
FOFFRACING's Avatar
Quoted: 0 Post(s)
I just did an oil change, I use your #1 method.
DONT TALK ABOUT IT, BE ABOUT IT!
FOFFRACING is offline
post #4 of 21 (permalink) Old 01-16-2009, 01:49 PM Thread Starter
Quoted: 0 Post(s)
From the looks of it we have the same vehicle so I'm leaning in your direction. What size socket do you need to get that plug out? I've just come out from under mine and it looks like I don't have one that's big enough...
Benobo is offline
post #5 of 21 (permalink) Old 01-16-2009, 02:30 PM
antichrist's Avatar
Quoted: 3 Post(s)
I use option one. Never had the oil pump lose prime, which is why some people do #3.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
74 Lightweight - The Antichrist (tag 6A666)
95 D1 - R380
95 D90 - R380
97 D1 - ZF
antichrist is offline
post #6 of 21 (permalink) Old 01-16-2009, 02:35 PM
antichrist's Avatar
Quoted: 3 Post(s)
This is actually the correct way.
1. Get drain pan, place under drain plug on engine sump.
2. Loosen drain plug with a wrench (note: righty tighty lefty loosey)
3. Remove drain plug from oil pan.
4. Curse loudly because hot oil just ran up your arm and spewed all over the ground, splashing off the catalytic converter.
5. Wipe off hands with rag, being careful to not rip off the bits of skin torn loose when the wrench slipped in step 1.
6. Pour oil absorbant (stolen from cat litter bag when your wife isn't looking) on spilled oil.
7. Check if oil is finished draining.
8. Quickly slide pan back under drain plug, to catch the last bit, from where you shoved it when the oil first overshot the pan.
9. Put more cat litter down.
10. Replace drain plug.
11. Tighten
12. Remove drain plug again because you realize you forgot the copper washer.
13. Fish around in hot oil in the bottom of the pan for the washer.
14. Replace washer, replace drain plug.
15. Remove filter
16. Go in garage to look for filter wrench because you can't perform step 15
17. Go ask wife to go to autoparts store for filter wrench because you can't find yours and you're too oily to drive, and you don't want her seeing the cat litter stuck to your back.
18. Have a beer while you wait for your wife to come back.
19. Realize you don't have any oil.
20. Frantically call your wife's cell.
21. Go get ice to put on your foot you hurt kicking the Rover's wheel when you heard your wife's cell ringing in the kitchen.
22. Think of other option and quickly grab phone book, look up parts store number and dial frantically.
23. Put down the phone and rush outside when you hear your wife drive up, trying to act nonchalant when you ask her to turn around and go back for oil.
24. Ignore her rolling eyes as you carefully specify the exact brand and weight you want, giving her several other choices in case they are out of what you want, plus other stores to check.
25. Have a beer while you wait for your wife to come back.
26. Ignore the fact when she returns that she bought the store brand oil.
27. Remove the filter.
28. Use your daughters bike, yes, the one with the tassles on the grips, to bike to the store for an oil filter because you know better than to ask your wife to go again.
29. Have a beer when you get home to console yourself from the strange looks you got at the parts store.
30. Install new filter.
31. Add new oil.
32. Frantically replace drain plug because you missed step 14 because you couldn't be bothered to read the instructions. After all, you are a man.
31. Dump more cat litter on the ground since you'd moved the drain pain when looking for the washer.
32. Get owners manual because you've no idea how much oil it takes.
33. Try to wipe the oil smudges off the manual's pages.
34. Replace the oil filler cap, put tools away (hanging up filter wrench so you can find it next time).
35. Tell yourself you'll get it later when it falls off the hook and lands behind a cabinet, in spite of the fact you looked behind it and saw two filter wrenches.
36. Wipe the oil off your hands and go get a beer.
37. Try your best to look innocent as you hear your wife cursing the cat for tracking cat litter all over the house.
38. Sleep on sofa because your wife noticed the cat litter still stuck to your back.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
97 D1 - ZF
post #7 of 21 (permalink) Old 01-16-2009, 02:49 PM Thread Starter
Quoted: 0 Post(s)
Ha! So thorough, antichrist, so exacting...
It answers my question, too. Looks like number 1 is the winner!
Benobo is offline
post #8 of 21 (permalink) Old 01-16-2009, 02:50 PM Thread Starter
Quoted: 0 Post(s)
Elemental: One question: are you the shamwow guy? If so, may I ask what kind of super-powered breakfast cereal you eat in the morning?
Benobo is offline
post #9 of 21 (permalink) Old 01-16-2009, 03:03 PM
The Zebra
LandyII's Avatar
Quoted: 0 Post(s)
11. Tighten
15. Remove filter
31. Add new oil.
2002 Discovery II Kalahari Edition - Stock And Going To Stay That Way
Towing a 2014 Lance 1685 Travel Trailer
Prodigy 3 Brake Controller
Fastway e2 Hitch
Absolutely NO problems
LandyII is offline
post #10 of 21 (permalink) Old 01-16-2009, 03:04 PM
The Zebra
LandyII's Avatar
Quoted: 0 Post(s)
Quit while you're ahead! You don't even want to hear his answer! Trust me, it's not about the cereal
Fastway e2 Hitch
LandyII is offline
post #11 of 21 (permalink) Old 01-16-2009, 03:05 PM
Elemental's Avatar
Quoted: 0 Post(s)
I use my slap-chop and grind up some rock, of which I snort, hammered down with a coupla Monster power drinks.
Before filming, I have a 3 way with a couple of methed out twin sisters, and rush off to filming.
post #12 of 21 (permalink) Old 01-16-2009, 03:12 PM
The Zebra
LandyII's Avatar
Quoted: 0 Post(s)
See what I was trying to tell you
Fastway e2 Hitch
LandyII is offline
post #13 of 21 (permalink) Old 01-16-2009, 03:33 PM
Elemental's Avatar
Quoted: 0 Post(s)
And, the sisters do not get a Shamwow to clean up with after... I save that for the girls I care about.
post #14 of 21 (permalink) Old 01-18-2010, 09:48 PM
xxljacket
Quoted: 0 Post(s)
what size wrench do I need to remove the oil drain plug?
mgispert@bellsouth.net is offline
post #15 of 21 (permalink) Old 01-18-2010, 10:02 PM
yesmar's Avatar
Quoted: 0 Post(s)
loosen oil plug, drain oil, unscrew and replace oil filter, changes oil plug washer with new one. tighten up, fill with oil. ....
11. Tighten
15. Remove filter
31. Add new oil.
yesmar is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Oil change - regular or Synthetics? aharbour Discovery Series I 11 09-28-2007 09:18 AM
PS Fluid Change wimp Discovery Series II 3 03-07-2007 12:30 PM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 03:50 AM
99 4.6 is superlocked and won't reset Spring Range Rover P38, Mk III and Range Rover Sport 9 12-05-2005 04:46 PM
You may post new threads
You may post replies
