#16 (permalink) | |
The guy with the Banhammer
![]() Join Date: Oct 2005
Also some springs, like OME, have progressive spring rates. So they can accomodate for different weights on different sides of the vehicle...at least while driving.
Josh Shapiro DII |
#18 (permalink) |
So one way you can balance out the front suspension would be to use one or two of Rovers Insulators, each one will add nearly 1/2". and are designed just for this purpose.
Go look at Expedition Exchange for these under Rover parts. http://www.seafoamsales.com/ Mike |
#19 (permalink) |
I would rather die on my feet then live on my knees.
I went with Big Blues from DAP and couldn't be happier. But if you go down to Pikes Peak Rovers get some OME springs. I would be willing to put them on for you that way you don't have to pay for the install. Good Luck!
#21 (permalink) |
The MoFab Man
Its common for a disco to have a smaller spring on the passenger side front . My 99 had this same Disco lean . I don't know why but this is common and not on all trucks for some reason but I run into 2 out of 5 D1's with the same funky spring ??who knows?? I went with OME 751's up front and I think 762's in the back and it rides better than stock and about 3 inches of lift with tires ! Theres my pennies ! oh if your in Co. Springs , Call Eric at Pikes Peak Rovers there great guys --- http://pikespeakrovers.com/index.php
* * http://www.MoFab.org * * * Are you gonna pass that ?? * 99' D1 55' S1 86" RHD SW 00' RR 4.6 HSE My Favorites: http://www.texasrovers.com/ http://pikespeakrovers.com/ http://oeminstock.com/ http://greatbasinrovers.com/ http://MyRover.net/ Yep, thats my truck in the avatar.... |
#22 (permalink) | |
Elephantitis penisitis
2 - Ho loads the shit out of his truck so how do you know the truck is loaded evenly. ![]()
#23 (permalink) |
Ok, I will give you that HO loads the shit out of his truck, I will also note that HO is not a small man. Ho knowing this would probably load his truck evenly, although looking through the rear window it doesn't look like there is a ton of gear in there. Although, it is possible he has a couple cans of water or fuel in there.
In this photo with an H2 next to it the H2 looks quite level compared to the D1. Matched springs are a hoax causing a Disco 1 to lean towards the drivers side.
I'm dressed and out of bed... What more could you possibly want? |
#24 (permalink) | |
#26 (permalink) | |
#28 (permalink) | |
#29 (permalink) |
Otherwise known as STEVE
The old "carefully matched spring" hoax... It's all BS.
Put matched, meaning identical, springs L and R and it'll sit level. Some Discos lean because of all kinds of strange reasons- I've seen binding bushings, worn bushings, bent anti-roll bars... There is no L and R spring anymore- same for series trucks too.
#30 (permalink) | |
If you were to replace the original springs with stock springs, you will get a slight lean to compensate for driver's weight and so forth. So, empty - without load - the Disco will slightly lean becoming more noticeable as they tire. With load, it will look even. I currently have OME springs and they are not matched - my Disco leans to one side - and the springs are not tired - and yes, they are installed correctly. Knowing what I know now...I will go with identical load bearing springs from BB or RTE next time. ![]()
