Old 11-20-2005, 03:17 PM   #1 (permalink)
AAXD's Avatar
Gallery: 1
Default Radio Code
I recently put a new alternator in my 97 D1. When I went to recode the radio, it wouldn't accept the code. I left the battery disconnected for most of the day and it still would not work after reconnecting it. Every time I drove the car I'd try the code and nothing worked for 3 days. Last night I was driving along and tried the code again and sure enough it worked. I can't find any rhyme or reason why it was not working before and then all of a sudden decided to accept the code. Has this happened to anyone else before?
Colin's Toys:
1972 Series III 88"
1997 Discovery XD
1983 Stage 1 109"
2002 Trek 4500
2005 Necky Looksha Sport
2007 Rans Rocket
2007 Honda Ruckus
Old 11-20-2005, 03:43 PM   #2 (permalink)
usually when the wrong code goes in it kicks you out for an hour or so.
Old 11-20-2005, 07:14 PM   #3 (permalink)
Default Radio code
The discovery 1 radios will lock out after three incorrect atempts at entering the radio code. To clear the lockout the key must be left on with the radio on for @ 1 hour. There is also a trick. There is a hole on the underside of the radio that lines up with a solder joint. By placing a small screwdriver or paper clip in the hole and contacting the metal case of the radio it will reset the lockout.The radio needs to be connected and on when doing this procedure.
TRAILCHARGER is offline   Reply With Quote
Old 11-21-2005, 07:35 PM   #4 (permalink)
Green DISCO UNO
Wink that's my problem 2
My code when off when they fix the breaks on my disco. The funny thing is that they never touch the battery
Eduardo is offline   Reply With Quote
Old 11-22-2005, 03:44 AM   #5 (permalink)
AAXD's Avatar
Gallery: 1
The weird thing with my truck is I typed in the correct code every time and it still locked me out. I never had that problem with my range rover, which to the best of my knowledge has the same radio.
Colin's Toys:
1972 Series III 88"
1997 Discovery XD
1983 Stage 1 109"
2002 Trek 4500
2007 Rans Rocket
2007 Honda Ruckus
Old 11-22-2005, 10:15 AM   #6 (permalink)
I would call the dealer that you bought it from and see if they have the code. Sometimes radios get changed and codes will be different. IF that dont work your pulling the radio for a number.
Old 11-23-2005, 10:56 AM   #7 (permalink)
I had to get the radio code from a local dealer and I had to enter it like 6 times before it accepted, apparently you get three tries and then it locks itself for an hour. From what the dealer told me sometimes it takes up to 12 times for the code to be accepted dependant upon how long the radio has been disconected... really odd but apparently thats how it works
thomas_lamb is offline   Reply With Quote
Old 11-24-2005, 12:27 PM   #8 (permalink)
My Rover is Like a Junky Always Needs A FIX!!
Rudy R's Avatar
Default code
I have done this...
1) turn off your radio
2) call dealer parts dept. tell them you need a radio code for your type of rover. they will ask you for the last six numbers of your vin#
3) they will look it up in the computer and give it to you
4) ask them how to set code
being that you radio has been off, all you will need to do is enter the numbers and on the last digit the radio will turn on
Rudy R
Rudy R
96 Disco 1
my wife said, if I get rid of my rover I could have a girlfrend... she would be cheaper.
Rover On
Rudy R is offline   Reply With Quote
Old 03-03-2007, 03:27 PM   #9 (permalink)
where am i?
moreheads's Avatar
do the dealers charge for getting you the code? or is it a right of passage for the owner.
moreheads is offline   Reply With Quote
