Old 11-24-2005, 04:02 PM   #1 (permalink)
Herbie85's Avatar
Default Radio Issues
I just recently purchase a 95 Disco and purchased the stock radio with the code of course to replace the aftermarket radio the previous owner had installed. But when he had the aftermarket radio installed a bunch of wires were cut to the specifications of that radio. I have reconnected the colored wires but there are other wires that could go anywhere. If anyone has pictures of the original wiring of their stock radio it would be very helpful and much appreciated. Thanks in advance.
Herbie85 is offline   Reply With Quote
Old 11-24-2005, 06:04 PM   #2 (permalink)
No relation to Felix The Cat
FelixLockhart's Avatar
Why in the world would you replace an aftermarket stereo with the stock one?
Felix J. Lockhart
1995 Land Rover Discovery (Series 1)
FelixLockhart is offline   Reply With Quote
Old 11-24-2005, 10:05 PM   #3 (permalink)
Rocky Mountain High
Funrover's Avatar
x2
Old 11-24-2005, 10:50 PM   #4 (permalink)
Herbie85's Avatar
the aftermarket didnt work for one and didnt have a tape player for my ipod
Old 11-25-2005, 05:46 PM   #5 (permalink)
[blinks] Umm, k...
An aftermarket stereo should have an auxillary input that plugs in directly, which should sound much better than a cassette adapter, and it'd be less likely to fail.
If you really must use the stock stereo (twitch), get ahold of the wiring diagram for the aftermarket one and use that to match up the colours, because the previous owner may have re-ran the speaker wiring to bypass the factory amp.
However, going from aftermarket to stock in this case is a serious downgrade in quality and features.
Felix J. Lockhart
Old 11-25-2005, 07:11 PM   #6 (permalink)
texasrover's Avatar
Felix,
Many aftermarkets do not have aux inputs... plus you need that cool WB feature on the factory radio. LOL
That is not a leak! That is undercarriage rust inhibitor.
98 Discovery
Old 11-25-2005, 07:28 PM   #7 (permalink)
texasrover's Avatar
You might want to think about going back to stock. Several reasons to switch... to begin with... factory amp failure or simply for better sound quality.
I would hate to see you spend all that money on purchasing a factory radio to install and then find out the aftermarket was used because the amps were not working.
98 Discovery
Old 11-26-2005, 09:36 AM   #8 (permalink)
Herbie85's Avatar
where are the amps located?
Old 12-02-2005, 08:44 PM   #9 (permalink)
Oh man you're in for one hell of a mess... The stock radio is the AMP. Since the wires were cut your kinda semi screwed. I got a aftermarket radio on my 95', I had to get the cables rewired because of the way the stock radio works. Now I need an amp, my sub doesnt work =/ because the radio is only 4 channel.
-Militant Grunt
Militant-Grunt is offline   Reply With Quote
Old 12-03-2005, 03:48 AM   #10 (permalink)
do it the easy way, go get an aftermarket deck, buy a wiring kit, put it together...done
rov'n is offline   Reply With Quote
