Old 09-04-2004, 01:38 PM   #1 (permalink)
Default Rear Door Hinges
The Rear door hinges on my Disco 1 are worn the door sits about 1/4 to 1/2 inch lower than the strike plate. Can the Hinges be replaced? I can find anything in the manual on the subject.
sidawson is offline   Reply With Quote
Old 09-04-2004, 06:56 PM   #2 (permalink)
Paulc's Avatar
Have you loosened the striker catch & the alignment plate (don't know the tech names) on the door frame & tried to set up a better fit for the door? If that didn't work…don't loosen your hinges or you'll forever be trying to get the door back to as good as it was, even if it isn't that good right now. If you loosen the hinges the door drops & that's it… even with 3 people, mine was still lower that it was from the from the factory.
A very experienced Land Rover tech, suggested using a floor jack & a couple of 2x4's to persuade the door back into position. Sounds ugly but it worked for me & apparently a few other Land Rover customers.
Good Luck
PaulC
98LSE
Paulc is offline   Reply With Quote
Old 09-04-2004, 09:17 PM   #3 (permalink)
What year model is it? Does it have the updated (D2-style) striker plate? The hinges are replaceable, but it's usually done at a body shop since they have to be painted.
Walk softly & carry a BIG SIX!
Steve83 is offline   Reply With Quote
Old 09-05-2004, 10:12 AM   #4 (permalink)
The Rover is a 94 Disco.
The top hinge is without a doubt the culprit. The two parts of the hinge are not lining up when the door is closed or open. I can’t make out if it’s the hinge pin that’s worn or the hinge part that goes in to the door. But my question has been answered, that I can get new hinges complete. Thanks
Old 09-05-2004, 12:29 PM   #5 (permalink)
Yes,the hinges come as an assembly,just need painting and bolting on.
Mick
scoobymick is offline   Reply With Quote
Old 09-18-2004, 09:16 AM   #6 (permalink)
Default hinges on back door
we had the same problem and had them replaced twice. the last time Landrover accused us of being negligent. We hardly drive the car and it seems if you open it at all over a period of time, the heaviness and weight of the door causes the problem
rover in amarillo is offline   Reply With Quote
