Links
Old 04-19-2008, 04:36 PM   #26 (permalink)
Tragedy! The bolt I had in the flange broke in it...
Any idea how to get this out? I read on an old Discoweb thread to hack it out
Ben Rover is offline   Reply With Quote
Old 04-19-2008, 06:53 PM   #27 (permalink)
antichrist's Avatar
Do you mean a bolt you had screwed in to the centering peg at the red line? The sruface indicated by the "62" is coated with loc-tite.
You might try a screw extractor. But if you were using a hardened bolt you might have a hard time drilling it out for the screw extractor.
I've found the best extractors are the type shown below (I think I got mine from Matco Tools)
If you get the bolt out, most people find the centering peg comes out better after applying heat.
rear-propshaft-upgrade-rear_diff_peg.jpg  rear-propshaft-upgrade-screw_extractor.jpg
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1
95 D90
Old 04-19-2008, 06:56 PM   #28 (permalink)
Yeah, that's where it broke. Luckily it broke because I apparently had some crappy old bolts mixed in with my good one, I should be able to extract it.
And I think you're right on the heating part, I just read in the manual that the part is supposed to be covered in Loctite before being jammed in there. A little heat might budge it good.
If not, the grinder will
Old 04-20-2008, 05:06 AM   #29 (permalink)
antichrist's Avatar
Always a good idea to look at a bolt head before you use it. I've found grade 5's, and even grade 2's, mixed in with grade 8's at the hardware store. Mostly I get them at a bolt supply house by the box, so it's not as much of an issue.
Some people say they got the peg out without heat, but I didn't even try on mine. I applied heat and it popped right out. It's been so long I can't remember if I used a slide hammer or not, which is what a lot of people use.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1
95 D90
Old 04-29-2008, 04:41 PM   #30 (permalink)
Finally got the conversion done, took two days... this is what's left of the old drive flange.
Scorpion Racing Rear Bumper Install w/pics. beavis4g63t Discovery Series I 10 10-17-2006 01:38 PM
TOO MUCH STUFF, Disco/RRC/Series/Defender/P38 GARAGE SALE RedRhinoProducts Land Rover Parts and Accessories 8 10-16-2006 09:41 PM
Oh man...(flame suit is on) 02disco2 The Lounge 9 03-27-2006 11:51 AM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 01:18 PM
Intermittent Driveline Vibration at 60MPH AdrianL Range Rover Classic 10 06-24-2005 07:52 AM
