Old 05-03-2008, 07:45 PM   #1 (permalink)
Javier
Gallery: 7
Default Rear Sunroof Leak!!
Hi everyone! I drive a 1997 disco SE7, im having problems with the rear sunroof, first of all, can't open it, and leaks, what do you guys suggest me to do? should I check the drain? and if I should, where is located?
-Javier-
DiscoIPR is offline   Reply With Quote
Old 05-03-2008, 11:32 PM   #2 (permalink)
A Chillin' Member
AZLandRvr's Avatar
Did you make sure the sunroof is completely in and not sticking out any way. Does the switch not work? You can manually slide it and see where it leaks...
Discovery Series I 96'
HID Lights
Full Custom Audio
5% Tint All Around, 20% on Whole Windshield
Flowmaster Catback
Smoked Tailights/Smoked Markers all around
AZLandRvr is offline   Reply With Quote
Old 05-04-2008, 09:30 AM   #3 (permalink)
Javier
Gallery: 7
Yes, the sunroof is completely closed, and there's no way to open it, not even manually, because is broken, anyways, I think the problem is with the drain, if someone can tell me where the drain is, I would really appreciate it. thanks!
Old 05-05-2008, 12:32 AM   #4 (permalink)
A Chillin' Member
AZLandRvr's Avatar
I have heard from other people to check the entire roof headliner. The plastic outlay of the sunroof is known to become brittle over time and allow water to accumulate under the lip of the sunroof tracks
HID Lights
Full Custom Audio
Flowmaster Catback
Old 05-09-2008, 09:54 AM   #5 (permalink)
Javier
Gallery: 7
Thank you very much!
From the makers of Spray on mud comes.... Elemental The Lounge 9 08-24-2007 11:24 AM
Sunroof leak rqwilliamsjr Range Rover Classic 8 11-21-2006 07:30 AM
TOO MUCH STUFF, Disco/RRC/Series/Defender/P38 GARAGE SALE RedRhinoProducts Land Rover Parts and Accessories 8 10-16-2006 09:41 PM
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 17 01-29-2006 01:18 PM
Leaking rear sunroof in 97 Disco BeattyD Discovery Series I 1 01-25-2005 07:17 PM
