Old 11-04-2007, 12:12 PM   #1 (permalink)
Default rear window switch mystery
The rear window switches on my Disco 1 do not work. They do operate using the switches on the master controls in the front though. I thought the switches in the back were bad. Both the passenger and driver's side switches aren't working. I checked the fuse and it is fine.
I purchased two new switches for the rear and the windows still doesn't go down.
This is the point where I get confused and slightly frustrated.
Is there anything that I forgot to check?
Thanks.
chrisusvi
chrisusvi is offline   Reply With Quote
Old 11-04-2007, 06:52 PM   #2 (permalink)
u did take it off lock right?
the center button in the front.
floridadiscoI is offline   Reply With Quote
Old 11-05-2007, 04:01 AM   #3 (permalink)
It may be your window lift ECU. Frequently, problems with the rear window operation are related to bad soldering joints on the circuit board in the ecu. If you are up for it, you can find the window lift ecu behind the glove box in the passenger footwell. If you want more details let me know what year your DI is and I can provide a bit more detail.
Paul Grant
paulgrant@mac.com
http://stores.ebay.com/Classic-Rovers
203-770-1699
Old 11-08-2007, 06:51 PM   #4 (permalink)
Paul I have a 1996 Land Rover discovery and I have the same EXACT problem that just started recently. My rear windows dont go down. But also my passenger side window only goes down 2 inches. Ill let you know what I find out if I figure anything out.
umoms is offline   Reply With Quote
Old 11-08-2007, 07:41 PM   #5 (permalink)
archaeology_student's Avatar
Gallery: 4
Lightbulb
Great article and step-by-step guide with detailed pictures on the Discoweb site
"The use of vegetable oils for engine fuels may seem insignificant today. But such oils may become in course of time as important as petroleum of the present time."
- Dr. Rudolf Diesel, 1912
MSN Blog with LR info and Photos
archaeology_student is offline   Reply With Quote
Old 05-14-2008, 08:47 PM   #6 (permalink)
Hello Gentlemen.
Thought I would piggy back this thread. I have EXACTLY the same problem. The Windows work from the Console, but not the doors. Have installed New rear window switches, Cleaned Plug inside door panel and my Window ECU Board seems well soldered. (I followed the Discoweb instructions) Any suggestions on what I can do next ?
Now, pardon my ignorance, but I am also assuming that The Console and Rear Door Window Switches would run off the same relay. Am I right in this assumption ? If not, where would I find the Rear Window Switch Relay ?
Cheers.
Jay
92 RRC "Garden Ornament" (Sold)
95 RRC LWB "25th Anniversary"
RangeRoverBoy is offline   Reply With Quote
Old 05-19-2008, 11:34 AM   #7 (permalink)
yeah i have a 1995 Land Rover Discovery and i have the same exact problems with the rear windows also. It suxs.
shady1147 is offline   Reply With Quote
Old 05-20-2008, 07:31 AM   #8 (permalink)
RonL's Avatar
Maybe the problem is the kid lock switch in the center console? center switchs work all the time with the "kid lock" engauged or unengauged but the door switch only works when the switch is unengauged.
You talked about replacing the door switch, maybe the "kid lock" switch is next to look at.
RonL
Hesston, KS
1997 & 1999 Discovery Series1
RonL is offline   Reply With Quote
Old 06-05-2008, 04:06 PM   #9 (permalink)
My junk is doing this same crap but I can't access the page that seemed so helpful on Discoweb. Anybody have a copy by any chance that you could send me?
Thanks
OV103 is offline   Reply With Quote
