» Sponsors
» Sponsors
Old 11-03-2009, 08:01 AM   #1 (permalink)
Default Rear Windows Don't Work?
have you seen this?!?!?
Window Lift ECU Repair Kit D1/95' RC | Land Rover Parts
my rear windows did't work so i was looking around for a new window ecu and found this.
if you click on the 'instructions' tab it tells you exactly what to do with it. i just used a length of wire with a couple connectors and bingo, rear windows work!
deeb is offline   Reply With Quote
Old 11-03-2009, 09:39 AM   #2 (permalink)
greenD1
wow. this would be great. I would love to have my rear windows back. anyone else have any experience with this?
greenD1 is offline   Reply With Quote
Old 11-03-2009, 10:44 AM   #3 (permalink)
i understand youre probably a bit weary considering how much of a LR greenhorn i am. but trust me, i did it last night in about 20 minutes....about 18 inches of wire, a wire cutter/stripper, and a couple wire couplers is all you need.
Old 11-03-2009, 11:59 AM   #4 (permalink)
greenD1
the instructions are great. I think I will give it a try this weekend. Thank
Old 11-03-2009, 03:46 PM   #5 (permalink)
my back windows only work after you hold the button down while you start it... Weird.
don't ask me how I found this out. But i'm gonna try this tonight and seem it doesn't fix the weirdness, thanks deeb
hootendi is offline   Reply With Quote
Old 11-03-2009, 04:32 PM   #6 (permalink)
greenD1
deeb, stoped by a hardware store on my way home from work, and am going to try this in the morning. I was confused on one point. when I connect to the pink and white wire, am I connecting to the side with the plug, or the wire leading away from the plug. thanks
If this works it will be the best 2 dollers I ever spent
Old 11-03-2009, 08:21 PM   #7 (permalink)
greenD1
I have good news and bad news. the good news is that the directions are easy to follow. Everything went together very well. the bad news is that my rear window still don't work. All this time I thought it was (and still may be) my ECU. Does anyone know what the green and white wire that I taped into is for. In my D1's life before me there were some bypasses put in by some one else. any ideas would be great
Old 11-04-2009, 05:45 AM   #8 (permalink)
just to clarify your last question, you use the wires that aren't attached to the plugs...
sorry to ask a stupid/offensive question, but were you sure to make good connections at each end of your wire and...did you plug your plugs back in?
just checked the disco manual for you...no chart of wires, couldnt find what that green/white ones for.
good luck
Old 11-04-2009, 06:55 AM   #9 (permalink)
It would help if you would state the year of the trucks you are working on.
osiristheclown is offline   Reply With Quote
Old 11-04-2009, 07:26 AM   #10 (permalink)
greenD1
It is easy to make simple/stupid mistakes like this. I double checked my connections, and made sure that everything was pluged in securly.
Is the green and white wire suposed to have power all the time? my test light is not picking up anything there. thanks
it is a 97 D1 se7
Old 11-04-2009, 08:05 AM   #11 (permalink)
it is a 97 D1 se7
ill check my wires for power this afternoon when i get home.
Old 11-04-2009, 02:52 PM   #12 (permalink)
greenD1
they work! I hate it when it is my fault, but it happens every once in a while. I was tracking an electrical short a few weeks ago, and pulled a couple of fuses trying to find my problem. It has been an ongoing problem with the windows and a short. When it would short out all of my dash lights and my right driving lights would go out. I have been frustrated by this for almost a month, but as of tonight, my rear windows work and the short has been found in the bulb in my rear bumper light. For once my wife is happy that I have been out working on the truck.
thanks deeb, I appreciate the help.
Old 11-05-2009, 05:41 AM   #13 (permalink)
niceone! good for you. gotta keep that wife happy!
not a problem dude, just glad to give back a little.
chad
Old 11-05-2009, 06:41 AM   #14 (permalink)
Nope, but i am going to order it. havent had rear windows working in over a year
lauderdalerover is offline   Reply With Quote
Detailing 101: Common Question and Answers, What and Where to buy stuff + Technique David General Land Rover Discussion 58 11-17-2009 08:24 AM
power window electrical issue hermanpj Range Rover Classic 10 02-01-2008 08:48 AM
Prison Vs. Work rmuller The Lounge 11 04-11-2007 09:02 AM
Got the windows tinted Hyde The Lounge 9 06-16-2005 07:20 AM
Problem with rear power windows Darryl Discovery Series I 7 09-30-2004 01:22 PM
