Old 09-16-2006, 06:41 PM   #1 (permalink)
natvboy's Avatar
Default refueling problem
Three times this has happened to me now since purchasing a year ago. Will not let me fill up more than 5 to 7 gallons. Gauge is less than 1/4 full. Is this common and what do I do to fix this.
natvboy is offline   Reply With Quote
Old 09-16-2006, 07:38 PM   #2 (permalink)
Could be you or the gas station itself.
Old 09-16-2006, 08:05 PM   #3 (permalink)
natvboy's Avatar
the me part could very well be true but it has been at three seperate stations.
Old 09-17-2006, 07:37 AM   #4 (permalink)
beavis4g63t's Avatar
when i drove my disco out of california the same thing happened to me. i had to put in gas so slow it would take me like 15 minutes to fill up the tank. i believe the answer is related to an emissions control device in the filler neck of the gas tank. i'll try to search some more for you today.
beavis4g63t is offline   Reply With Quote
Old 09-17-2006, 02:49 PM   #5 (permalink)
JesusIsLord
9dawgs's Avatar
Gallery: 2
I've had this problem on occassion. It appears to me that at certain gas stations they have the pump pressure adjusted up really high. When I go to a different station, where the gas doesn't pump as quickly, I have no problems. The solution I found was to avoid the pumps where the gas is dispensed at a high pressure. My suggestion is to try a few different stations until you find one where you don't have the problem. Hope this helps!
9dawgs
'99 Discovery I
'99 Chevy Astro 4X2 w/4" Lift (family truckster)
17' Basstracker w/40HP Mercury
11' Jon Boat w/numerous antique outboards
9dawgs is offline   Reply With Quote
Old 09-17-2006, 02:59 PM   #6 (permalink)
AFIROVER
afirover's Avatar
my solution to the same issue
afirover is offline   Reply With Quote
Old 09-17-2006, 03:06 PM   #7 (permalink)
I used a syringe to squirt some fuel injector cleaner down the breather hole, and that fixed the problem.
errant is offline   Reply With Quote
